Ultimate Handyman Home
Decking help
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Gardeners World
stingray316
Junior Member
PostPosted: Tue Sep 02, 2008 6:34 pm    Post subject: Decking help Add User to Ignore List Reply with quote
l want to build a decking around 12x12 and would like to know where is the best place to get decking wood from and since this is my first attempt some help and advice on constucting it..
Back to top
The Weegie
PostPosted: Tue Sep 02, 2008 6:43 pm    Post subject: Re: Decking help Add User to Ignore List Reply with quote
Hi there. Any decent builders yard or timber merchants will have a wide range of decking.
With regards to tips on construction. Check out the Ultimate Handyman guide to decking on the Section links.
Back to top
Inky Pete
Member
PostPosted: Tue Sep 02, 2008 6:47 pm    Post subject: Add User to Ignore List Reply with quote
Assuming that it's 12 feet not meters, and that you don't want to run the boards at 45 degrees, I'd get 4.2m boards delivered by someone like Travis Perkins. That way you can run single boards all the way across without any joins.
Back to top
PostPosted: Tue Sep 02, 2008 7:02 pm    Post subject: Add User to Ignore List Reply with quote
Local wood yards can often be cheap for decking supplies. The las stuff I bought was from empress timber in Clitheroe, they were much cheaper than anywhere else.
For the how to-
http://www.ultimatehandyman.co.uk/diy/decking/index.htm
DIY | DIY Video
Back to top
stingray316
Junior Member
PostPosted: Tue Sep 02, 2008 8:23 pm    Post subject: Add User to Ignore List Reply with quote
Yes its going to be 12 ft. Any idea how much 4.2m boards are. How much do you think the whole job will cost me..
Back to top
savoytimber
Junior Member
PostPosted: Mon Oct 06, 2008 3:47 pm    Post subject: Add User to Ignore List Reply with quote
I'm assuming you've done it now anyway, but the boards should cost around £186 for thick ones or £110 for 20mm ones, frame would come in at around £65 if you used standard 4 x 2 for a flat deck. By the time you've got screws and ensele etc I reckon you are looking at approx £300 for a complete decking kit.
Ian
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Gardeners World All times are GMT
Page 1 of 1
