Page 1 of 1
[ 11 posts ] |
| Author |
Message |
Lancashire Lass
Posted: Wed Oct 27, 2010 7:41 pm |
| Newly registered Member |
Joined: Wed Oct 27, 2010 7:23 pm Posts: 5 Has thanked: 1 times Been thanked: 0 times
Hi I live in a mid terraced house built in the 1880s. I bought the house 5 years ago and have had a continuous problem with damp in the spare room upstairs/down into the dining room downstairs where the chimney breasts have been removed. The damp gets much worse when it rains and is leaving a track of damp on the wall where the flue will be, all the way downstairs. We have had the leading, flashing, pointing and ridge tiles replaced. The bishop pots have been taken down and replaced with chinamans hats all of which has cost us a few hundred pounds each time. A few months ago we had the whole roof re-slated (at a cost of £2k) and we still have the problem. I really struggle to get the roofers to return after I tell them it hasn't worked and have to get someone different each time. I really don't know what else to do and are considering removing or lowering the stack now as a final option - which again will be very expensive and has the potential not to be a solution. Any other suggestions would be very welcome. many thanks
| Top |
northwales4u
Posted: Wed Oct 27, 2010 7:47 pm |
| Senior Member |
Joined: Sun Jul 25, 2010 5:32 pm Posts: 2181 Location: Wrexham, Wales Has thanked: 45 times Been thanked: 124 times
if the chimney breasts have been removed why didnt you remove the stack on the roof too (hope it is supported well) then you would have no problems at all
| Top |
register or
log in
Lancashire Lass
Posted: Wed Oct 27, 2010 7:50 pm |
Hi Thanks for replying so quickly. The chimney breasts had already been removed when we bought the house and the survey didn't detect any signs of damp.
| Top |
register or
log in
Posted: Wed Oct 27, 2010 7:56 pm |
| Site Admin |
Joined: Sat Jul 16, 2005 8:06 pm Posts: 20633 Location: Darwen, Lancashire Has thanked: 125 times Been thanked: 392 times
So it sounds like the chimneys have been removed from downstairs, but they remain upstairs in the bedrooms.
Is that correct?
If it is correct are there any vents in the chimney breasts?
If not that could be the cause of the problem. Damp could of got down the chimney, but can't be drawn out properly as there is not enough air flow, so the venturi effect of the wind blowing over the chimney pots can't suck out the moisture.
| Top |
register or
log in
Lancashire Lass
Posted: Wed Oct 27, 2010 7:58 pm |
There are two rooms downstairs and two bedrooms upstairs. The chimney breasts are still present in the front room and front bedroom but both have been removed from the downstairs back room and back bedroom - there are no vents.
| Top |
register or
log in
thescruff
Posted: Wed Oct 27, 2010 8:01 pm |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39977 Has thanked: 187 times Been thanked: 2112 times
If it's a shared flue, it could be coming down the neighbours side
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
Posted: Wed Oct 27, 2010 8:03 pm |
| Site Admin |
As you have already said that you have chinamans hats fitted, I'd fit some vents into each of the chimneys (in the bedrooms), so that the chimneys can draw out any moisture.
where the chimney has been removed on both levels you can also remove a single brick from the stack in the loft, which will also help the chimney draw out the moisture.
| Top |
register or
log in
Lancashire Lass
Posted: Wed Oct 27, 2010 8:05 pm |
It's not a shared chimney so I think we'll give the vents a try next, thanks for your advice.
| Top |
register or
log in
Lancashire Lass
Posted: Wed Oct 27, 2010 8:59 pm |
Sorry, I've just spoken to my husband and it is vented through a couple of bricks being removed in the loft.
| Top |
register or
log in
register or
log in
pye191f
Posted: Tue Nov 09, 2010 6:51 pm |
Joined: Tue Nov 09, 2010 4:25 pm Posts: 7 Has thanked: 2 times Been thanked: 0 times
When organic material such as wood and coal are burned, the deposits within the soot ie. sulphates and ammonium salts eat into the mortar and masonry.
These contaminates can be hygroscopic, in other words they can attract moisture from the air. When it rains the moisture content within the property can increase also, so the contaminated area will become wet.
If all of the above suggestions fail, then you will have to hack off the plaster to the chimney breast area, isolate the exposed masonry with a cementitous slurry and a 3:1 sand cement render.
You can then skim the area with finishing plaster.
| Top |
register or
log in
Page 1 of 1
[ 11 posts ] |
