Page 1 of 1
[ 2 posts ] |
| Author |
Message |
simontreid
Posted: Sat Aug 14, 2010 9:31 pm |
| Newly registered Member |
Joined: Sat Aug 14, 2010 6:22 pm Posts: 3 Has thanked: 3 times Been thanked: 0 times
Hi all
I patched up alot of the blown plaster on the outside of the house last year and then painted it with two coats. I hope this will sort some of the damp issues which I have guessed have come from water penetrating from the outside
How long should I leave it before I can decorate inside. It is a house built in the 1880's and the walls are basically granite and rubble etc. Should I wait before it totally dries out which could take quite a while or could I use some of the 'damp' type paints if people feel they are effective
cheers
| Top |
Posted: Tue Aug 24, 2010 8:55 pm |
| Site Admin |
Joined: Sat Jul 16, 2005 8:06 pm Posts: 20029 Location: Darwen, Lancashire Has thanked: 70 times Been thanked: 340 times
You should leave it as long as possible to ensure that it is completely dry.
| Top |
register or
log in
Page 1 of 1
[ 2 posts ] |
