Page 1 of 1
[ 14 posts ] |
| Author |
Message |
iornw1
Posted: Thu Aug 18, 2011 12:02 pm |
| Newly registered Member |
Joined: Thu Aug 18, 2011 11:45 am Posts: 5 Has thanked: 2 times Been thanked: 0 times
I have a damp patch which has appeared on an old chimney breast. The room is on our ground floor and I recently had the house renovated and this damp patch appeared 6 months later. As you can see from the photo the damp is about 30cm across and very localised and the rest of the wall is fine.
I would welcome suggestions on what the cause is and how to fix it.
| Attachments: |
File comment: Photo of damp area
Doc1.doc [909.5 KiB]
Downloaded 122 times
| Top |
wine~o
Posted: Thu Aug 18, 2011 9:11 pm |
| Senior Member |
Joined: Sat Jan 10, 2009 3:49 pm Posts: 7465 Location: hants/dorset border Has thanked: 166 times Been thanked: 611 times
Sorry..can't open that, Cheapskate that I am I have open office..any chance of attaching a pic or two??
_________________ . If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : http://www.donnasdreamhouse.co.uk/__________________________________ __________________________________ Verwood HandymanI Know it says I'm On-line, but I might have just left myself logged in, whilst I'm out....
| Top |
register or
log in
mikew1972
Posted: Fri Aug 19, 2011 11:05 am |
| Senior Member |
Joined: Sun Jan 27, 2008 5:54 pm Posts: 1051 Location: North West Has thanked: 0 times Been thanked: 69 times
I'm not going to open an office document either. Not even going to try. It could contain a virus!
_________________ Mike
| Top |
register or
log in
ayjay
Posted: Fri Aug 19, 2011 12:01 pm |
| Senior Member |
Joined: Wed Nov 17, 2010 5:51 pm Posts: 1003 Has thanked: 7 times Been thanked: 128 times
Open Office scans it for nasties before opening. So here it is , (reduced to a more manageable size). Attachment:
_________________ One day it will all be firewood.
For this message the author ayjay has received gratitude : iornw1 |
| Top |
register or
log in
wine~o
Posted: Fri Aug 19, 2011 6:36 pm |
| Senior Member |
Do you have any vents on the chimney breast?
| Top |
register or
log in
iornw1
Posted: Mon Aug 22, 2011 7:45 am |
Yes just out of the photo is an air vent which is at a similar height to the damp patch.
| Top |
register or
log in
mikew1972
Posted: Mon Aug 22, 2011 9:35 am |
| Senior Member |
More photos needed I'm afraid. 1 showing the whole wall inside and 1 showing the chimney outside if possible please.
| Top |
register or
log in
iornw1
Posted: Mon Aug 22, 2011 12:57 pm |
The chimney is not exposed to the exterior elements as this wall connects to my neighbour's house as my house is terraced.
| Attachments: |
| Top |
register or
log in
mikew1972
Posted: Tue Aug 23, 2011 8:21 am |
| Senior Member |
I'm hoping someone else will jump in with suggestions here because thats a bit od a puzzling one. Could therebe an old back boiler in behind there all corroded and leaking? Are there any pipes there or above there or maybe behind there in the neighbours house that could be leaking? It just seems an odd place for the damp patch if it was water coming down the chimney from damaged flashing or pointing etc. perhaps someone else will know better?
| Top |
register or
log in
root
Posted: Tue Aug 23, 2011 9:17 am |
| Senior Member |
Joined: Thu Apr 28, 2011 12:20 pm Posts: 2579 Location: Sussex Has thanked: 166 times Been thanked: 169 times
have you spoken to your neighbours they may have a leak they dont know about on thier side of the party wall?
| Top |
register or
log in
amarg
Posted: Tue Aug 23, 2011 12:39 pm |
| Senior Member |
Joined: Sat Feb 11, 2006 7:15 pm Posts: 355 Has thanked: 10 times Been thanked: 28 times
That is a strange place for a localised damp patch like that
| Top |
register or
log in
iornw1
Posted: Wed Aug 24, 2011 3:02 pm |
I have checked in my neighbour's house and they have the same type of old chimney breast on their side too, and there is no sign of damp their side.
This room is on the ground floor and my house is 4 storeys high, so I dont think that water can be entering down the chimney. I do have a working gas fire the floor above.
I have read that that sometimes salts can come out from the wall which were created by gases from the original cole fires. But it seems strange to me that I have only had this problem since my house was renovated and redecorated. I am thinking about having the plaster stripped back in this local area, leave to the air for sometime and then redecorate again. Lets see if that will work....
| Top |
register or
log in
BedfordPropertyCare
Posted: Wed Sep 07, 2011 4:20 pm |
Joined: Fri Aug 05, 2011 9:34 am Posts: 22 Has thanked: 0 times Been thanked: 2 times
Hi there,
It could be a patch of hygroscopic salts. In older chimneys the soot etc. can leave deposits in the chimney which draw moisture out of the atmosphere. These migrate through plaster when wet and can draw moisture out of the air (especially when humid).
The other alternatives I can think of are: 1. some source of moisture in the area (eg. leaking plumbing - already mentioned) 2. random patch of different material (eg. bonding plaster) while the surrounds are waterproof render
Either way, I think the solution required is to: a. hack off the plaster +300mm in all directions b. apply a tanking slurry (or alternative waterproofing mechanism) c. make good and redecorate.
Hope that helps,
Link removed by admin
Please read and understand the forum rules
| Top |
register or
log in
iornw1
Posted: Sun Sep 11, 2011 12:35 pm |
Many thanks to all for the advice
| Top |
register or
log in
Page 1 of 1
[ 14 posts ] |
