It is currently Sat Apr 21, 2018 2:24 pm
 Post subject: Damp patch above Shower
PostPosted: Wed Jan 10, 2018 5:58 pm
Hey Guys,
When we moved into our home a few years ago we knew the ensuite ceiling had a damp patch, I put this down to the fan not working correctly.
We changed the bathroom about 18 months ago and I replaced the fan, I explained to the guy in the plumber's merchants that there was damp and I needed a really good fan to help extract the steam so he gave me one that he said he used in his own home.
Well the damp came back after a few months and I really need to get it sorted, the damp patch is pretty big but I would like to understand what is wrong exactly and how to not only fix the issue but how I can prevent this from happening in the future. I have also noticed a build up of damp around the window in the bedroom where the ensuite is.
The ensuite is approximately 3m by 2m with a large double shower, the fan extracts to the outside and is fitted in the ceiling approx 1m away from the shower head. I had first thought of simply moving the whole fan to directly above the shower, however, I'm not sure if this alone will fix the problem. We leave our window in the bedroom and the ensuite on vent and try to open the window when we shower but it doesn't help much.
Would I benefit from just moving the fan or would a more sophisticated vent system be needed?
Thanks for your help on this guys.
PostPosted: Wed Jan 10, 2018 7:03 pm
Has thanked: 1404 times
Been thanked: 3629 times
damp patch could be caused by condensation in the shower cubicle or could be a leak from above... does your fan have a timed over-run ?
Pics may help.
PostPosted: Wed Jan 10, 2018 7:49 pm
Yea the fan runs for about 2 minutes after the light is switched off.
PostPosted: Wed Jan 10, 2018 8:05 pm
Mr. Grumpy
Has thanked: 31 times
Been thanked: 115 times
2mins is not enough. Many can be adjusted up to 20mins
Does it have a trickle feature an humidistat?
Makes a big difference
PostPosted: Wed Jan 10, 2018 8:27 pm
Concur 2 minutes is not enough. 15/20 minutes would be better.
PostPosted: Wed Jan 10, 2018 8:32 pm
I need to check if it can go up further but I don’t think it has a humidistat feature.
I was thinking of changing it to an in-line extractor as I read these are more powerful. I could then separate it from the light or add a humidistat possibly.
Would something like this below help alongside the extractor?
https://www.vent-axia.com/range/lo-carbon-pozidry-pro
PostPosted: Fri Jan 12, 2018 6:33 pm
There is normally an adjustment to run the fan for up to 20 minutes after switching off.
PostPosted: Sat Jan 13, 2018 10:45 pm
Has thanked: 36 times
Been thanked: 109 times
I suspect the route of the problem is your ceiling/ window reveals are not correctly insulated above/behind. Thus the dew point of the ceiling (coldness) is causing the water vapour in the air to condense. If it were condensing all over the ceiling & walls, sink, toilet etc then that would suggest you've got a ventilation problem.
Remember also that you don't just need to pull warm wet air out of the bathroom, warm dry air has to come in (usually under/around the bathroom door), or it will be trying to pull a vacuum and be very ineffective. Same applies if your flexi duct is pinched in the loft or (if through the wall type) the back draft shutters can jam shut against the flexi ribs.
PostPosted: Sun Jan 14, 2018 12:11 am
Has thanked: 8 times
Been thanked: 9 times
It cold be hot/cold insulation if it's affecting another part of the house. Is the room fully insulated/ fully uninsulated?
PostPosted: Sun Jan 14, 2018 1:50 am
Has thanked: 131 times
Been thanked: 33 times
Hi Stuart
First thing I would do is get up in the loft space and check the duckting that takes the damp air to the outside. Normally a white flexible pipe. Is it full of water at some points? Is the insulation wet where the ducting touches it?
I have seen a whole section that dips into the insulation full of water when the warm damp air re condensates and runs back down the pipe before it gets to the outside. As the pipe fills with water the gauge narrows expediting the problem.
The very thin plastic pipe then splits and starts to drip onto the insulation that in turn causes a damp patch on the ceiling below.
Some pics would help a lot to help determine damp or mold
Cheers
James
I love hard work, I could watch it all day
