Page 1 of 1
[ 8 posts ] |
thescruff
Posted: Wed May 12, 2010 1:27 pm |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39977 Has thanked: 187 times Been thanked: 2112 times
Where are the pipes ? in the wall or the floor running under the wall.
What material are they, copper or plastic.
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
duncanl
Posted: Wed May 12, 2010 1:39 pm |
| Newly registered Member |
Joined: Wed May 12, 2010 12:25 pm Posts: 6 Has thanked: 1 times Been thanked: 0 times
Hi there - thanks for the quick response.
The pipes run horizontally, under the radiator (just above the skirting board) on the outside of the wall, when they reach the outside wall, about 3 meters from the damp, they go into the wall and run up towards the boiler on the floor above. I hope that's clear. They are made of copper.
| Top |
register or
log in
thescruff
Posted: Wed May 12, 2010 2:00 pm |
| OAP |
I think you'll need to cut a section out and see what if anything is behind there in that case.
What is above the wall, a bathroom or shower for example.
| Top |
register or
log in
duncanl
Posted: Wed May 12, 2010 2:09 pm |
There is a hallway and a kitchen above the portion of the wall where there is damp however that part of the kitchen doesn't have any pipes or taps.
I haven't worked with partion before (I don't think I am very adept at this) - how difficult is it to make good after cutting the section out? What tools / materials would I need?
Thanks for your help!
| Top |
register or
log in
thescruff
Posted: Wed May 12, 2010 2:28 pm |
| OAP |
You would need to re-board and skim, but really that is something to worry about after you know whats going on.
If you're not very competent or confident for that matter, look for a recommended Handyman, There's quite a few use this forum so one may be in your area.
| Top |
register or
log in
duncanl
Posted: Wed May 12, 2010 4:17 pm |
Thank you for your help with this... I think I will get someone in to have a look at it.
| Top |
register or
log in
thescruff
Posted: Wed May 12, 2010 4:48 pm |
| OAP |
As said a good Handyman will cover all the skills to investigate and repair, without the need for several different trades.
| Top |
register or
log in
Page 1 of 1
[ 8 posts ] |
