Orphean wrote:
We have purchased an old detatched property built approx 1930`s, it has 3 chimney`s, 2 on external wallls, and 1 internal. After heavy rain, large damp patches appear on the 9" solid internal walls, around the area of the chimney breasts,and on both sides of the internal chimney breast. The lead flashings have been replaced, the chimneys have been re-pointed and sprayed with water sealer. The original roof, is obviously passed its sell by date, but the attic, although cold, is dry, with no evidence of leaks. The external walls are rendered at bedroom level and brick at ground floor level.
We have had the roof inspected by several people, and opinions range from leaking render to a complete new roof. I should add that the chimney`s have`nt been used for years, and we were aware of damp patches when we bought the property, although we had no idea how difficult it would be to eradicate the problem.
I can believe we have a leak in one or two places, although i have sat in the attic during heavy rain and have seen no leakages, but cant understand how 3 chimneys in 3 sperate bedrooms are showing damp patches after heavy rain.
We are considering demolishing the internal chimney and removing the plaster on the affected walls of the other two chimney`s and painting on bitumastic paint, then replastering.
If anyone can advise us how to beat this problem, we would be eternally grateful
1) Could you tell us what sort of caps, if any, are on the chimney pots?
2) Could you get us external photos?
John
