It is currently Wed Jan 23, 2019 3:54 pm
PostPosted: Wed May 30, 2018 3:24 pm
Has thanked: 3 times
Hello
I need to make a straight cut along my driveway of 4cm depth (2cm tarmac, 2cm of foundations). I'm taking away some of the grass and laying a few flag stones to give more space when getting out of the car (need room for a pram!)
I have a Bosch pks 18 li cordless circular saw, if I bought the proper blade would the saw do the job? It only mentions cutting wood and metal in the manual but its a fairly small amount of work it needs to do.
Alternatively I could probably get the lend of a small angle grinder but it wouldn't cut deep enough, if I went this route, would a bolster and hammer finish the job?
Obviously the circular saw would be the easiest option, but I don't know if it would have enough power.
Any advice would be much appreciated.
Adam
PostPosted: Wed May 30, 2018 4:33 pm
Has thanked: 627 times
Been thanked: 1795 times
It will knacker the circular saw blade quite quickly as it will heat up and loose the hardness. If you can borrow one, an angle grinder with a stone cutting disc would be best. Use a bit of wood as a guide to run it along to keep straight. They are not that pricey see https://www.toolstation.com/shop/p96949 and https://www.toolstation.com/shop/p89755
Painting with BIN
For this message the author dewaltdisney has received gratitude : adamCCC
PostPosted: Wed May 30, 2018 4:46 pm
Has thanked: 60 times
Been thanked: 630 times
In all honesty hire a petrol diamond asphalt saw (water cooled) otherwise as soon as you hit the tarmac its going gunge up the blade and engulf you in smoke
you may want to get a quote on the job tbh
For this message the author Bob225 has received gratitude : adamCCC
PostPosted: Wed May 30, 2018 5:16 pm
Been thanked: 135 times
best is a corded 7 1/4" circular saw with a cheapo tarmac blade.
using your saw might get it gunked up with melting bits of asphalt .
or use a corded angle grinder with a cheap blade if the wheel can be safely fixed.
only use any of the machines with its guard. dont take them off to fit a blade.
mark your line and make very shallow say 5mm - 10mm cuts. dont go deep in one go.
thats how we constantly cut concrete with a chucked up masonry blade in a circ saw
For this message the author wes56 has received gratitude : adamCCC
