It is currently Wed May 23, 2012 5:11 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 10 posts ]
 Post subject: cutting square hole
PostPosted: Tue Nov 23, 2010 5:27 pm
Has thanked: 2 times
What is the best ( and easiest) way to make cut outs in existing tiling for electrical boxes?
I could use an angle grinder but it would be v. messy!
 Post subject: Re: cutting square hole
PostPosted: Tue Nov 23, 2010 5:38 pm
Been thanked: 327 times
4.5 inch angle grinder, shut the door and open the window.
Wet cutter
Special scoring bit for manual tile cutter which will gradually gouge out the back of the tile, depending on what sort of tile it is. Very time consuming.
For this message the author royaloakcarpentry has received gratitude : dunaird
PostPosted: Tue Nov 23, 2010 7:15 pm
Has thanked: 134 times
Been thanked: 468 times
if your not used to using an angle grinder
drill 3 or 4 8mm holes in each corner and cut to a strait edge held on with sticky tape
make sure the cut out is 2-3mm bigger than the back box
PostPosted: Tue Nov 23, 2010 7:31 pm
Doesn't a Roto Zip do cuts out of tiles?
PostPosted: Tue Nov 23, 2010 7:38 pm
Has thanked: 4 times
Been thanked: 9 times
Dremel multi or one of those "Excact saws" seen on QVC maybe? (ive got one but never ever used it!)
PostPosted: Tue Nov 23, 2010 8:21 pm
Has thanked: 125 times
Been thanked: 392 times
The Bosch PMF 180E will cut a square out of a tile as long as you use the tile cutting blade, but it won't be as easy as the angle grinder method.
DIY | Donnas dream house
PostPosted: Tue Nov 23, 2010 10:41 pm
Mr. Grumpy
Been thanked: 32 times
I have done what UHM suggested with the grit blade on the PMF but its very slow, You get there in the end
PostPosted: Wed Nov 24, 2010 12:54 am
Has thanked: 144 times
Been thanked: 217 times
I disagree, close the window, open the door, go outside :lol: :lol: :lol:
but yeah, angle grinder, rotozip, plunge cut
what type of tile by the way?
Professional Kitchen & Bathroom Fitters | Master Painters and Decorators | Brighton & Hove
PostPosted: Wed Nov 24, 2010 9:25 am
Thanks all for response, I think I'll go with grinder and get wife to do it!
PostPosted: Wed Nov 24, 2010 9:43 pm
Been thanked: 1 times
Wet cutter, remove the guard, glazed side up, plunge cut, quite easy, have a practice on a couple of old tiles, you'll soon get the hang of it..........
For this message the author bodgitandscarper has received gratitude : dunaird
