-> Tiling Forum |
| Author |
Message |
handyman Senior Member
Joined: 16 Jan 2006 Posts: 2863 Location: Alderley Edge, Cheshire
Posted: Fri Nov 02, 2007 7:17 pm Post subject: cutting 12mm tile backer board |
it says its easy to cut with a stanley knife, then it just snaps..........does it fook!
I have used a jiggy to cut them using up the cheapy SFD blade pack. They blunt quickly (partly cos there pish). Is there a special blade for cutting backer board, or another way of cutting it? _________________ Go on, adopt a greyhound http://www.dgrescue.org.uk/ ..........................................................................  |
| Back to top |
panlid Senior Member
Posted: Fri Nov 02, 2007 7:23 pm Post subject: |
i use a stanly knife unless it is a narrow strip, then i use my cordless circular saw.
for a stanly lightly score it along your straight edge. then remove the straight edge and score again but heavier. then snap. |
| Back to top |
dewaltdisney Senior Member
Posted: Fri Nov 02, 2007 7:26 pm Post subject: |
On Aquapanel you have to cut both sides through the fibreglass mesh. I use a good heavy duty utility knife and score hard to cut through. It then snaps easily but if it is a thin section you have to nibble it back with pincers.
DWD |
| Back to top |
Only-Me Senior Member
Posted: Fri Nov 02, 2007 9:34 pm Post subject: |
You can get a tungston carbide tipped thingy from Topps Tiles.
Never used them myself............
Used a tile saw blade in a jiggy.........that lasted a bit longer than ordinary blades. |
| Back to top |
Posted: Fri Nov 02, 2007 9:54 pm Post subject: |
just ordered some carbide jiggy blades.
Will try a circular saw on it as well.
Thanks for info _________________ Go on, adopt a greyhound http://www.dgrescue.org.uk/ ..........................................................................  |
| Back to top |
Posted: Fri Nov 02, 2007 10:02 pm Post subject: |
Turn the circular saw blade around. Heard it works better running the wrong way.
Only on hardibacker kind of stuff mind  |
| Back to top |
tim'll fix it BANNED
Joined: 18 Jan 2006 Posts: 2137 Location: Leicestershire
Posted: Fri Nov 02, 2007 10:39 pm Post subject: |
i cut aquapanel with an old hand saw _________________ Decking |
| Back to top |
bathstyle BATHROOM DESIGN AND INSTALLATION
Posted: Sat Nov 03, 2007 12:46 am Post subject: |
| Hardibacker say that you need to score three times before snapping, similar to Aquapanel |
| Back to top |
Posted: Sat Nov 03, 2007 7:27 am Post subject: |
i know, thats what I did, and it isnt a nice 'snap', it sort of tears, so isnt a sharp cut _________________ Go on, adopt a greyhound http://www.dgrescue.org.uk/ ..........................................................................  |
| Back to top |
Posted: Sat Nov 03, 2007 9:57 am Post subject: |
| You'll never get a perfect cut when you score and snap, where are you using hardibacker anyway? |
| Back to top |
jason123 Senior Member
Joined: 16 Dec 2006 Posts: 1239 Location: Stellaville
Posted: Sat Nov 03, 2007 10:13 am Post subject: |
I used an old handsaw on AP, its concrete based and as others have said the mesh needs to be cut or it gets messy. All the edges looked a bit ragged, but then its not PB is it. _________________ Stella Stella Stella oy oy oy |
| Back to top |
Posted: Sat Nov 03, 2007 10:32 am Post subject: |
| bathstyle wrote: |
| You'll never get a perfect cut when you score and snap |
good, thats what i thought. I thought i may be doing something wrong
| bathstyle wrote: |
Well, i normally use aquapanel, but topp tiles had hardibacker for £10 a sheet, so thought i'd try it. Using it on shower area and floor. _________________ Go on, adopt a greyhound http://www.dgrescue.org.uk/ ..........................................................................  |
| Back to top |
sjohnstone Junior Member
Posted: Mon Nov 05, 2007 1:26 pm Post subject: Cutting Tile Backer Board |
I recently installed Wedi board (cement backer similar to Marmox) in my shower enclosure.
To cut it I stuck masking tape down to mark where I wanted to cut, then simply used a handsaw (with hack saw blade) - I reckoned the smaller the teeth, the less chance the blade would rip the cement face.
...worked a treat. |
| Back to top |
Posted: Mon Nov 05, 2007 7:42 pm Post subject: |
| Wedi and Hardibacker are very different products, Wedi is extremely easy to cut in comparison |
| Back to top |
Posted: Mon Nov 05, 2007 8:36 pm Post subject: |
is the wedi board very light weight? _________________ Go on, adopt a greyhound http://www.dgrescue.org.uk/ ..........................................................................  |
| Back to top |
