It is currently Sun Jul 22, 2018 9:23 am
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
 Post subject: Cut scaffold tubes
PostPosted: Thu Aug 11, 2016 8:27 pm
Has thanked: 12 times
Been thanked: 2 times
Hi guys, what will cut through scaffold tubes easily and quickly? I have about 30 I need to cut that have been fixed together to make a shed that is now redundant. It's about 30 years old and the fixings ain't shifting so cutting my only option I think. There heavy steel I think if that makes a difference.
Sent from my SM-G920F using Tapatalk
 Post subject: Re: Cut scaffold tubes
PostPosted: Thu Aug 11, 2016 8:37 pm
Has thanked: 228 times
Been thanked: 175 times
Angle grinder with a thin metal cutting disc.
PostPosted: Thu Aug 11, 2016 8:44 pm
Has thanked: 93 times
Been thanked: 347 times
Angle grinder, a 9" will get through 48mm tube from one side, or a 4.5 or 5" grinder, you'd need access around a fair bit of the pipe to cut from the sides.
PostPosted: Thu Aug 11, 2016 8:50 pm
It's accessible just some above head height etc so maybe the smaller grinder be better! Any particular disc and will one disc do the lot?
PostPosted: Thu Aug 11, 2016 8:52 pm
Has thanked: 422 times
Been thanked: 3903 times
I would cut the bolts as the poles may fetch a few quid, should be easier and safer anyway.
PostPosted: Thu Aug 11, 2016 9:19 pm
Cheers scruff will they be easier to cut than the tubes?
PostPosted: Thu Aug 11, 2016 9:38 pm
Assuming you can get to them much easier, once cut give it a bash with the hammer if it's rusted up. Try one first and see what you think.
PostPosted: Fri Aug 12, 2016 10:00 pm
Which ever grinder you use, make sure you cut in such a manner that as the pole comes free, it doesnt pinch the blade.
A thin 1mm disc, decent make, eg Norton, Klingspor, Reca, should do you a a good few cuts in each tube if used properly.
PostPosted: Sat Aug 13, 2016 8:28 pm
Decided to cut the clips that clamp the tubes together with a small hand grinder, at the moment going through 1 disc per two clips, would this be reasonable? Using wickes discs as found some in the box!
PostPosted: Sat Aug 13, 2016 10:53 pm
Are you using metal cutting discs
PostPosted: Sun Aug 14, 2016 6:13 am
Yes I am :)
PostPosted: Sun Aug 14, 2016 8:11 am
Has thanked: 42 times
Been thanked: 657 times
Trying lightening up on your pressure, let the disc do the work, pressing hard will just stress the grinder and wear out the discs faster.
PostPosted: Sun Aug 14, 2016 3:07 pm
OK will try that, thanks
PostPosted: Wed Sep 07, 2016 3:33 pm
Quick question guys, will the discs with the raised centre fit any grinder? I've used flat cutting discs mainly but found a couple of this type too?
PostPosted: Wed Sep 07, 2016 8:44 pm
Has thanked: 17 times
Been thanked: 83 times
In general, yes, but they will normally be thicker. 3mm upwards. They will take longer to cut as they are removing more material.
Sticking with the 1mm flat discs will get the job done faster,
