It is currently Sat Feb 23, 2019 8:52 am
Post new topic Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
 Post subject: Crimping 2.5mm T&E
PostPosted: Mon Jan 15, 2018 6:01 pm
Mr. Grumpy
Has thanked: 31 times
Been thanked: 116 times
Ok I need to extend a 2.5mm T&E tomorrow and just had a question about crimping. So it looks like I ....
1) slide the heatshrink down the cable first
2) stagger the joints so the butt connectors are not bunched up.
3) Use 3 blue Butt connectors, no copper poking out
4) Ratchet Crimpers
5) apply the heatshrink
6) have a coffee and kitkat
I am curious about something
Q) is the earth part of a 2.5mm (sq) cable only 1.5mm (sq)? If so, why use a blue connector, should you not use a red connector? :scratch:
PS: as I understand it the name "2.5mm T&E" cable means the copper wires has a cross-sectional area of 2.5mm (squared) so the actual diameter is less (1.78mm as I work it out)
 Post subject: Re: Crimping 2.5mm T&E
PostPosted: Mon Jan 15, 2018 6:28 pm
Has thanked: 70 times
Been thanked: 144 times
Doesn't answer your question but,
a, you can get heat shrink crimp connectors, meaning you do not need heat shrink tubing as well;
b, if using heat shrink tubing, you could just solder the wires together in an overlap, meaning you don't need the crimp connectors at all.
You specify a colour, therefore you are insulated crimps, so why use tubing as well?
PostPosted: Mon Jan 15, 2018 6:33 pm
Has thanked: 233 times
Been thanked: 177 times
Wagon connector not better for this application?
PostPosted: Mon Jan 15, 2018 6:36 pm
Has thanked: 1533 times
Been thanked: 3855 times
Good but not as good as Wago connectors... :lol: :hiding:
PostPosted: Mon Jan 15, 2018 6:40 pm
Mr. Grumpy
I saw those heat shrink connectors but the ones I have are just the standard insulated butt connectors.
As I understand it, you still need an outer heat shrink over the whole cable (i.e. to replace the grey PVC you strip away.)
PostPosted: Mon Jan 15, 2018 6:43 pm
Mr. Grumpy
Indeed , but I have a pile of various types of crimp connectors and the Wago ones come in a box of 50 or 100.
No other reason than saving myself a trip to screwfix :wink:
PostPosted: Mon Jan 15, 2018 6:53 pm
Approved Electrician
Has thanked: 168 times
Been thanked: 585 times
I would use a red connector for a 2.5mm ^2 T&E earth core, as it is as you, say 1.5mm^2.
If the crimped connections are not in an existing back box or similar then the heat sleeving is required as you are crimping single cored cables.
PostPosted: Mon Jan 15, 2018 6:55 pm
I stand corrected.
PostPosted: Mon Jan 15, 2018 6:57 pm
Mr. Grumpy
Excellent, thank you sir! They will be under the floor.
PostPosted: Mon Jan 15, 2018 7:16 pm
Then you can fit them in an adaptable box or choc box.
The same rules apply for wago connectors.
PostPosted: Mon Jan 15, 2018 7:17 pm
Has thanked: 16 times
Been thanked: 98 times
I know you don't want a trip to screwfix, but these are cheaper than wago connectors.
https://www.screwfix.com/p/ideal-spliceline-in-line-wire-connectors-pack-of-10/42201
Has thanked: 62 times
Been thanked: 650 times
you can get wago connectors in small quantity's, I got ten at a local wholesaler, I don't like crimps on mains, I would rather use a J/B (if it can be accessed)
random google link
https://www.tlc-direct.co.uk/Manufactur ... index.html
PostPosted: Mon Jan 15, 2018 7:30 pm
Mr. Grumpy
Thanks guys, I forgot about TLC.
I might just get a handful for the tool box anyway
PostPosted: Mon Jan 15, 2018 7:41 pm
Not only TLC, also try CPC, free postage over £5 (exc. vat).
TLC £3.60 under £50 (local to a branch) or £3.90 under £150 (further afield) - plus 20% tax.
I get a few from CPC or TLC every time I order other stuff.
PostPosted: Wed Jan 24, 2018 12:01 am
Has thanked: 147 times
Been thanked: 213 times
I know they use crimps in trunking sometimes.
I was taught to overlap the wires the length of the metal inside the crimp( so lay them together in from each end or whatever), then when you crimp up the crimp it squeezes the whole lot together. You may then require a crimp larger than you might expect for the size of wire, because it is effectively double the thickness. If you are doing a same end crimp then by all means twist together if stranded wire, or lay together as before.
For this message the author Timllfixit has received gratitude : DIY_Johnny
