It is currently Sun Feb 25, 2018 1:33 pm
Visit Thermo worx
PostPosted: Mon Aug 21, 2017 10:53 pm
Has thanked: 14 times
For a long time the vent pipe connected to the back of our Creda Simplicity tumble dryer kept disconnecting from the hole behind the tumble dryer periodically. Today I finally figured out why. I went along the outside wall to the spot where the duct leaves the house. When the tumble dryer is on air is supposed to exert from this vent, however, it didn't do this. I removed the brown grill attached to the wall which acts as the end point of the ducting. I could then feel air flowing out from the tumble dryer. I then looked at the brown grill and could see that it was blocked up with dust. I got this cleared and placed the brown grill back on the wall.
The dust filter inside the tumble dryer leaks a little which probably explains the dust blockage at the end point of the ducting where it exits the house. This reminder that the dust filter should be cleaned after each use of the dryer! It would seem that the blockage stopped the air from exiting the house and therefore the pressure build up caused the duct to disconnect from the rear of the tumble dryer.
Air is definitely flowing through the ducting now because part of the ducting that I can touch gets warm which it did not do before. I'm delighted I got this issue sorted ! :huray:
PostPosted: Tue Aug 22, 2017 7:39 am
Has thanked: 3 times
Been thanked: 92 times
Thats becausr you have a fancy grill with an insect grill rather than the cheap ones with flaps that flip up
PostPosted: Thu Aug 24, 2017 6:32 pm
Approved Electrician
Has thanked: 151 times
Been thanked: 531 times
Or one just without the insect screen, the ones with flaps rattle in the wind.
PostPosted: Thu Aug 24, 2017 8:00 pm
Has thanked: 38 times
Been thanked: 1183 times
Sorry to state the obvious but the reason they have screens is not to trap the outgoing lint, but to stop insects coming into your dryer. I would clean it and put it back.
PostPosted: Tue Sep 05, 2017 11:11 pm
Yup. Got it all cleaned and put it back. Running much better now. Very pleased.
PostPosted: Tue Sep 05, 2017 11:15 pm
I didn't fit the 'fancy' grill ;) the cow boys that built the extension fitted it.
Do the grills with the flaps not have an insect screen?
PostPosted: Wed Sep 06, 2017 5:34 pm
Most don't. Some can have one fitted. But often what happens is, the lint jambs the hinges and holds the flaps open. Like all things of this nature, you are supposed to clean it, but almost no one does.
For this message the author someone-else has received gratitude : flembot
