It is currently Sat Jul 21, 2018 12:42 pm
PostPosted: Fri May 12, 2017 8:22 am
Has thanked: 4 times
Been thanked: 1 times
The render is absolutely solid. Just below (no more than a mm) the hairline cracks is a thin iron band. This iron is causing the cracking when hot( fire place used regularly). What is this iron doing spaced every 2 feet? Can I hack it out? Should I use expanded mesh and a thick render? Or Cementone and paint with Bedec masonary paint? Be really grateful for some solid advise. Also tried uploading photo but didn't work!
PostPosted: Fri May 12, 2017 9:20 am
Has thanked: 13 times
Been thanked: 182 times
Could you post a couple of photos please.
davyp1
For this message the author davyp1 has received gratitude : richardb
PostPosted: Fri May 12, 2017 12:50 pm
Has thanked: 397 times
Been thanked: 1406 times
The usual problem is that the pics are too large, reduce the size down to 1000 pixels wide and it'll be OK.
how-to-post-photo-s-t9415.html
For this message the author ayjay has received gratitude : richardb
PostPosted: Fri May 12, 2017 6:51 pm
Ok I think this photo should show enough. You can see the rust.
PostPosted: Sun May 14, 2017 9:39 am
Has thanked: 239 times
Been thanked: 1105 times
The top half of stack needs re-rendering
For this message the author cotswold builders has received gratitude : sajeel
PostPosted: Sun May 14, 2017 10:01 am
Thanks for advise and I hope to get this discussion rolling. The problem is not the render as previously stated. The problem lies in the embedded iron just benieth the surface which heats and causes hairline cracking.
The question really is what the heck is this metal doing there in the first place and can it be lacked out?
ayjay? davyp? Anyone?
Sent from my iPad using Tapatalk
PostPosted: Sun May 14, 2017 10:50 am
Has thanked: 160 times
Been thanked: 5 times
In not an expert but I remember there being some structure metal in chimney, the idea of mesh and render may work the crack is due to movement only real solution would be to underpin house around chimney area that involves digging underground and will be expensive. Removing metal brackets will make cracks worse in my opinion
PostPosted: Sun May 14, 2017 11:45 am
Wow! underpinning the house. This thread has already become surreal!
For this message the author richardb has received gratitude : sajeel
