It is currently Wed May 23, 2012 4:49 pm
PostPosted: Tue Oct 18, 2011 9:52 pm
On a solid wall (ie 9in brick), can crack stitching bars be fitted from the inside.
Usually there are outside only, so does it make any difference to fit from inside?
PostPosted: Tue Oct 18, 2011 10:36 pm
Has thanked: 134 times
Been thanked: 468 times
no expert but would have thought it needs to be done on both at that thickness :dunno:
this off course would only be visible on the outside but as i say i don't have a clue :scratch: :lol:
PostPosted: Wed Oct 19, 2011 12:04 am
Has thanked: 18 times
Been thanked: 28 times
I've seen it done, but you'll have to remove plaster etc and make good if done on the inside?
The companies that make them like helifix or twist fix have helplines you can use
PostPosted: Fri Oct 21, 2011 7:12 pm
Has thanked: 15 times
Been thanked: 160 times
They are normally fitted to the outside skin, but if yours is a solid wall, nothing wrong with fitting them inside.
