It is currently Thu Feb 09, 2012 7:37 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 14 posts ]
 Post subject: Coving effect patch up
PostPosted: Wed Sep 01, 2010 11:30 am
Has thanked: 1 times
Hello everybody,
First post - please be kind!
I'm doing a lot of renovation on our new house, and I'm happy doing general plastering / skimming etc to flat walls. The lounge, however, has a coving effect which needs some work and I'm not sure how to approach it.
I've dot and dabbed soundbloc plasterboard onto the walls, as the neighbours are pretty old and have their TV loud. The only trouble is, that this takes the depth of the wall further out than the coving effect.
I was recommended by the plasterer who taught me to use stop bead to bring the coving back out - which I've done on some of the patch ups where the electricians have chased out (the place needed a full rewire) - and it worked well. The only trouble is, that this means 're-building' the top part of the coving effect a bit further out. I'd go back to my 'tutor' but he lives miles away and isn't exactly technically minded when it comes to emailing pictures!
I'm happy doing that, but I don't know how to do the corner bits. I've thought about UPV arch bead and lighter mesh and corner jointing tape but I'm not sure how to go about it. I've attached a few pictures so you can hopefully get a better idea of what I mean... Its the corners above the fireplace. Hopefully you'll see what I mean.
Any advice would be greatly appreciated - I'm still early on in my plastering career, so this is a steep learning curve for me! Hopefully this isn't a stupid question but has an easy answer!
File comment: The front of the fireplace.
File comment: A better angle of the curve. And you can see on the left hand side, how level the front now is with the plasterboard (losing the overhang effect)
File comment: You can see the bit I need to patch up here - I've done others like this around the house, but none where I needed to bring the coving out. They worked fine with some stop bead.
File comment: The white 'coving' above the fireplace area on the right and left curves diagonally into the room - it is this I'm unsure of.
PostPosted: Wed Sep 01, 2010 11:45 am
OAP
Has thanked: 181 times
Been thanked: 1983 times
I would ask in the sparky's forum about the cables. :roll:
PostPosted: Wed Sep 01, 2010 12:19 pm
Cables? I don't have any questions to do with the cables....
PostPosted: Wed Sep 01, 2010 12:41 pm
Plasterer
Has thanked: 8 times
Been thanked: 28 times
Not 100% sure i know what you mean but have you thought about chopping back the a bit of where the arch meets the board so its flush to stick your bead up?
I think i would have left a little bit more of a gap when putting the boards up to bring them flush with where your picking up the wall mate
I'd also get a sheath covering for those cables too :thumbright:
PostPosted: Wed Sep 01, 2010 12:58 pm
Thanks so much for the reply evile,
I probably haven't explained this the best!
I don't want it flush to, around the rest of the room there is a little bit of an overhang so the white bit comes out from the wall about 6mm where it meets the blue boards.
I left the boards a little bit lower so I could put a stop bead horizontally running along the length of the top of them to 'rebuild' this a little further out. It's the bit at the sides that sweep up to the ceiling that I can't get my head around - how to have that good edge on a bend.
Am I making any sense? Apologies if I'm making everybody go :wtf: !
PostPosted: Wed Sep 01, 2010 1:05 pm
OAP
Maybe not, but you should have.
But hey ho what does the plumber know. :roll:
PostPosted: Wed Sep 01, 2010 1:08 pm
I don't understand? Could you please be more specific with what question I should be asking? I said at the beginning that I was no expert. I'm not sure if you're trying to be funny - If so, I don't get the joke. If you have a serious point to make please tell me so I can do something about it.
PostPosted: Wed Sep 01, 2010 1:31 pm
OAP
I would think the cables should have something covering them, don't know if it's a reg or just good practice.
PostPosted: Wed Sep 01, 2010 2:47 pm
Ah, I see what you mean now.
I just phoned the electrician who fitted them and said not to worry - it is good practice to have them, but not worth going and changing the ones I've already repaired.
PostPosted: Wed Sep 01, 2010 3:01 pm
OAP
Not to worry :wtf: if it's good practice why didn't he do it.
I still think it's a requirement under part P. :dunno:
PostPosted: Wed Sep 01, 2010 3:04 pm
Ha Ha. Good point - I guess he thinks it's up to the plasterer to fit.
PostPosted: Wed Sep 01, 2010 3:08 pm
OAP
I've just asked the question in the sparkies forum.
PostPosted: Wed Sep 01, 2010 6:46 pm
Has thanked: 75 times
Been thanked: 35 times
I would say just put a bit of batten at the bottom and use bonding plaster to give yourself the basic shape. Then multi-finish plaster skimmed over the top at the end. Keep the bonding plaster below your finished plaster level. Remove batten at the end to give you your edge/lip back.
For this message the author lagi has received gratitude : melbadog
PostPosted: Thu Sep 02, 2010 10:24 am
Thanks Lagi. I'll give it a go.. :-)
