Ultimate Handyman Home
Cork tiles
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Painting & Decorating Forum
luke
Junior Member
PostPosted: Thu Dec 06, 2007 9:18 pm    Post subject: Cork tiles Add User to Ignore List Reply with quote
I am currently decorating my hallway and have discovered Cork Tiles on 4 of the walls under the woodchip paper. Can anybody advise the best way to remove the tiles and glue before i re-paper ??
Back to top
Welsh Decorator
PostPosted: Fri Dec 07, 2007 12:00 am    Post subject: Add User to Ignore List Reply with quote
The tiles should be the easy part, its the glue that is the unknown? scratch
If thet have been stuck with 'contact' adhesive, then you will probably be looking at haveing a plaster in, as the stuff to soften the glue is solvent, and quite strong as well, you would need air fed breathing aperatus to work with it! Not recomended! Shocked
You might be able, depending on how thick the glue is, scratch to use a smoothing product, probably the Artex one, then a light sanding once dry, Thumbright other than that, it's a plastering job.
Come back and let us know how you get on, post some pictures if you can. Thumbright
Back to top
View user's profile Send private message Yahoo Messenger
feva
PostPosted: Fri Dec 07, 2007 6:04 pm    Post subject: Add User to Ignore List Reply with quote
id hang my self if that was me finding that!!!!
Back to top
luke
Junior Member
PostPosted: Sat Dec 08, 2007 8:26 pm    Post subject: Add User to Ignore List Reply with quote
Thanks for your advise its appreciated.
I have managed to remove the tiles from one wall so far but it has left a sticky residue. I will keep going and try to post some pictures.
Back to top
roylec
Junior Member
PostPosted: Tue Dec 11, 2007 9:29 pm    Post subject: Add User to Ignore List Reply with quote
Try water in case it was a vegetable based adhesive, you might try steaming if you have the kit, if you don't then test it with a kettle before you go out and buy it..
Chances are that it's contact adhesive. Probably Evostick or some DIY supplied gunk bought with the tiles. If this is the case, and you can't make good a square metre in an hour, then you have only two options:
1) Set aside a couple of days to use a good paint scraping tool - get one from a trade painting and decorating shop - it should be a bar like a claw-hammer. You'll also need a sander with some pretty abrasive paper, and some wet and dry paper for the fine work when the adhesive is down to almost nothing. Finally, you'll need to patch in places with some finishing plaster - I always prefer to mix this myself rather than use the tub variety.
2) Get a spreader in - probably £250 - £350 to skim your hall. Wait a week before painting, mist properly and you'll have a fantastic result. That two days can be spent down the pub instead.
Back to top
Welsh Decorator
PostPosted: Wed Dec 12, 2007 1:28 am    Post subject: Add User to Ignore List Reply with quote
£250/350? where are you two guy's? sounds slightly cheep for a plaster'r? or am just to kind? and would do it for the cost of a day plus matt's?
Back to top
roylec
Junior Member
PostPosted: Wed Dec 12, 2007 1:31 am    Post subject: Add User to Ignore List Reply with quote
I'm in London, and paid a spread £300 this afternoon for a hallway, including ceiling. The hallway is five metres long, has six doors in it, and quite a few awkward spots.
Back to top
Welsh Decorator
PostPosted: Wed Dec 12, 2007 1:33 am    Post subject: Add User to Ignore List Reply with quote
Reasionably priced for the 'smoke' Thumbright
Back to top
roylec
Junior Member
PostPosted: Wed Dec 12, 2007 1:35 am    Post subject: Add User to Ignore List Reply with quote
A damn good spread too. Difficult to come by in London, if you find one, do all you can to keep him on-side.
Back to top
Welsh Decorator
PostPosted: Wed Dec 12, 2007 1:36 am    Post subject: Add User to Ignore List Reply with quote
No different up here then! Crying
Back to top
luke
Junior Member
PostPosted: Wed Dec 12, 2007 8:57 pm    Post subject: Add User to Ignore List Reply with quote
Great advise again thanks.
I have managed to clear 1 wall at the bottom of the stairs, which took most of the day Saturday but has left some adhesive. Only 3 to go more walls to go !!.
I will continue the battle over the weekend and let you know how it goes.
Cheers......
Back to top
Telmay
PostPosted: Thu Dec 13, 2007 7:46 am    Post subject: Add User to Ignore List Reply with quote
Good luck Luke - crappy job but will be worth the effort in the long run
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Painting & Decorating Forum All times are GMT
Page 1 of 1
