-> Plastering Forum |
| Author |
Message |
Handy-Andy's Lovechild Junior Member
Posted: Mon Aug 13, 2007 9:40 pm Post subject: Converting bedroom to bathroom |
Hi there, I'm in the process of converting a small bedroom into a bathroom. Should i be doing anything to make the existing plastered walls water/moisture proof? I have removed a wall of lathe and plaster and boarded it - should i have used a specialist board? Should i use a specialist plaster?
As you can guess i am a plastering amateur - any help is appreciated!!!
Cheers, Si. |
| Back to top |
ultimatehandyman Site Admin
Posted: Mon Aug 13, 2007 10:17 pm Post subject: |
Most walls will be ok with normal plasterboard, but if it is an area where it will be subject to much moisture, for example in shower cubicles then use aquapanel, especially if you use mosaic tiles. You would also need to tank it do do a proper job.
http://www.ultimatehandyman.co.uk/building_a_shower.htm _________________ DIY | DIY Video |
| Back to top |
tim'll fix it BANNED
Joined: 18 Jan 2006 Posts: 2137 Location: Leicestershire
Posted: Tue Aug 14, 2007 12:28 am Post subject: |
a new bathroom requires Building Control too _________________ Decking |
| Back to top |
