Page 1 of 1
[ 14 posts ] |
| Author |
Message |
taxi48
Posted: Thu Jan 20, 2011 5:46 pm |
| Newly registered Member |
Joined: Sun Jun 15, 2008 7:17 pm Posts: 13 Has thanked: 1 times Been thanked: 0 times
hi house built 1980 condensation in up stairs ensuite any suggestions or help thanks
| Top |
81ash
Posted: Thu Jan 20, 2011 9:15 pm |
| Senior Member |
Joined: Thu Mar 18, 2010 2:01 pm Posts: 107 Has thanked: 1 times Been thanked: 5 times
Hmm, not a huge amount of details. Does the bathroom have a window?
Can i guess that the bathroom does'nt have an extractor fan fitted?
| Top |
register or
log in
taxi48
Posted: Fri Jan 21, 2011 2:52 pm |
bathroom does have window does have extractor fan fitted thanks
| Top |
register or
log in
northwales4u
Posted: Fri Jan 21, 2011 3:04 pm |
| Senior Member |
Joined: Sun Jul 25, 2010 5:32 pm Posts: 2181 Location: Wrexham, Wales Has thanked: 45 times Been thanked: 124 times
Does the extractor fan work everytime you use the bathroom?
| Top |
register or
log in
taxi48
Posted: Fri Jan 21, 2011 4:00 pm |
above shower only recently put in turn with pull cord small bathroom window open does not seemed to make anydifference the window was always opened thanks
| Top |
register or
log in
keithjeb
Posted: Fri Jan 21, 2011 4:47 pm |
| Senior Member |
Joined: Thu Dec 16, 2010 8:28 pm Posts: 140 Has thanked: 3 times Been thanked: 16 times
wow, and breathe.....
Whereabouts is the condensation? Roof, walls etc?
Is it droplets or just damp marks?
When do you get it (after showering, when heating is on? bathing etc) or is it there all the time? Have you recently done anything to the ceiling, new loft insulation perhaps?
| Top |
register or
log in
taxi48
Posted: Fri Jan 21, 2011 5:28 pm |
USALLY GET IT A NIGHT CEILING AND WINDOWS THERE ARE SOME BLACK MARKS THE ROOF SPACE ABOVE IE INSULATED 25 YEARS AGO THANKS
| Top |
register or
log in
keithjeb
Posted: Fri Jan 21, 2011 10:21 pm |
| Senior Member |
It sounds like a lack of ventilation, but it could be any number of things, if it's at night when the heatings on part of me thinks it could be a damp floor, but it could well be missing tiles or damaged felt in the loft, is it dry up there?
| Top |
register or
log in
81ash
Posted: Sat Jan 22, 2011 6:11 pm |
| Senior Member |
Did you put the extractor fan in to try and sort the problem or for other reasons? Is the problem better / worse / same since you installed it. Is the window single or double glazed? I assume you are wiping the mould away with bleach / water solution?
| Top |
register or
log in
taxi48
Posted: Sun Jan 23, 2011 3:27 pm |
THE EXTRACTOR FAN WAS PUT IN TO SEE IF IT WOULD HELP NEVER MADE ANY DIFFERENCE THANKS
| Top |
register or
log in
merseygull
Posted: Sun Jan 23, 2011 4:20 pm |
| Senior Member |
Joined: Tue Oct 26, 2010 7:40 pm Posts: 823 Location: Teignmouth, Devon Has thanked: 7 times Been thanked: 17 times
Taxi48, please don't shout... (turn capslock off)
The info so far is a bit scanty... can you post a pic of the problem?
ATB,J.
_________________ I'm a Doctor, not a Plumber/Plasterer/Electrician/Engineer!
| Top |
register or
log in
taxi48
Posted: Mon Jan 24, 2011 5:31 pm |
WINDOWS WET tiles wet on walls cieling wet very little mildew ok not shoutin thanks
| Top |
register or
log in
81ash
Posted: Mon Jan 24, 2011 7:39 pm |
| Senior Member |
That sounds a bit odd. If you've got condensation you'll be getting mould / mildew growth. When you say things are wet, do you mean it is like this all the time? As the previous poster said a few pictures of the room would help.
| Top |
register or
log in
taxi48
Posted: Tue Jan 25, 2011 3:38 pm |
the wet tiles and windows dont seem as bad now the very cold weather has gone niether is cieling sorry boy i dont know how to post pictures on internet thanks
| Top |
register or
log in
Page 1 of 1
[ 14 posts ] |
