It is currently Wed Jul 18, 2018 12:25 am
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
 Post subject: Condensation on pipes?
PostPosted: Wed Oct 18, 2017 4:00 pm
Hello
I have been in a new build house now for about 18 months.
Since we have been in there we have experienced excess water around the main water pipes (which reside under the sink) that are connected to the mains supply.
The problem being that these pipes seem to drip, we have been told that this is just condensation by the builder and all plumbing is ok
I just wanted a second opinion really, as I now notice that the pipes are gradually turning black now and they mark clothing/skin whenever reaching under the sink.
Every few weeks I am wiping out the cupboard...
Is this normal!?
PostPosted: Wed Oct 18, 2017 4:04 pm
Has thanked: 1072 times
Been thanked: 1006 times
It's condensation.* Don't dry clothes in the house. Try to ventilate.
I'd also insulate the pipes if possible.
http://bit.ly/2yxdCes
*ETA Assuming it's been checked for leaks, which you say it has. It's looks like condensation.
PostPosted: Wed Oct 18, 2017 4:58 pm
Has thanked: 25 times
Been thanked: 94 times
Condensation is common on cold water pipes pop some pipe insulation around them that should do the trick! :thumbright:
http://www.diy.com/departments/climafle ... 868_BQ.prd
http://www.diy.com/departments/climafle ... 869_BQ.prd
Most pipes look to be 22mm the smaller one is 15mm.
PostPosted: Wed Oct 18, 2017 5:01 pm
Has thanked: 564 times
Been thanked: 1666 times
Is that bit of string wet? It is a way of wicking a small leak into one place. Just wondered.
The incoming water is cold and any moisture in the air will condensate on the pipes. So why is there so much moisture laden air in the cupboard? Leave the doors open to allow the warmer air to circulate and see if that affects anything.
Painting with BIN
PostPosted: Wed Oct 18, 2017 5:05 pm
Agreed.
PostPosted: Wed Oct 18, 2017 5:12 pm
Thanks, i will get some lagging.
PostPosted: Wed Oct 18, 2017 5:13 pm
Has thanked: 1452 times
Been thanked: 3725 times
I've never seen a condensation issue that bad on an incoming main. I wonder if there is an issue with a leak after the pipework leaves the cupboard which would cause that pipe to be permanently cold ?
Put the sharp end of a screwdriver on the cold pipe and your ear to the blunt end, with all taps and other outlets shut can you hear water running or a "bubbling" sound ?
PostPosted: Wed Oct 18, 2017 5:16 pm
Has thanked: 811 times
Been thanked: 885 times
Turn off all taps and water outlets and go and check your water meter.
The little 'star' in the middle will turn even with the slightest of leaks/drips.
If there is no movement after a couple of minutes, you have no leak.
I have also never seen condensation affect pipes in this area.
Also check your sink wastes for any possible leaks.
Dave
www.drlgas.co.uk
PostPosted: Wed Oct 18, 2017 5:20 pm
My sink cupboard had bad condensation till I lagged the pipes.
Usually on an outside wall with cold water running through and unheated space below it, bound to get condensation.
PostPosted: Wed Oct 18, 2017 5:22 pm
Not saying either w~o or gas4you are wrong, but I think it depends where you are. We get it under the sink here, definitely no leaks etc. It's the damp climate down here near the sea. The cistern in the one loo is a PIA for it as well.
PostPosted: Wed Oct 18, 2017 6:07 pm
Same here downstairs WC aǹd we are near the sea too, do you think it might be tidal? :huray:
For this message the author toolbox has received gratitude : Dave54
PostPosted: Wed Oct 18, 2017 6:26 pm
Don't know. Do you get surfers in the pan? :shock: :mrgreen:
PostPosted: Wed Oct 18, 2017 6:40 pm
Has thanked: 49 times
Been thanked: 516 times
imho they look like there smothered in flux not wet, the copper should be copper coloured not black and tarnished you can see where the pipes have been wiped with a damp rag giving a glazed effect
There the worst I have seen in some time, my 15 year old niece could do a cleaner job
use Wire wool or a clean fit strip aka clean up strip and clean it up, I think Stevie wonder was the site inspector
edit. if it was wet it would have the green and white crusties
PostPosted: Wed Oct 18, 2017 6:46 pm
:-P
PostPosted: Wed Oct 18, 2017 7:01 pm
@ OP are you near the sea ? I only work around Verwood Ringwood (Not near the sea) Bournemouth on occasion...which is a bit nearer the sea...
Though the properties I worked on in Sandbanks didn't have that problem... https://en.wikipedia.org/wiki/Sandbanks
