It is currently Wed Feb 20, 2019 3:23 am
PostPosted: Tue Jan 16, 2018 6:56 pm
Has thanked: 201 times
Been thanked: 24 times
We have the choice of a concrete floor (Celotex type insulation boards and then concrete) or a floating floor (Level layer of concrete then celotex boards and then 22mm OSB boards) on top of the insulation in our extension - which would you recommend?
many thanks
PostPosted: Tue Jan 23, 2018 8:35 am
Has thanked: 13 times
Been thanked: 182 times
Morton wrote:
many thanks
You also need to consider what form of heating your extension is to have.
With a concrete constructed floor slab, it is normal to have a structural slab initially with mesh reinforcement.
Followed by Celotex insulation layer.
Then with a 75mm sand/cement screed over this.
If you had decided on under-floor heating, this would have been laid before the screed and subsequently have been contained within it.
I am unable to think of any advantages gained from using an OSB floating system?
Davyp1
For this message the author davyp1 has received gratitude : Morton
PostPosted: Wed Jan 24, 2018 9:44 am
Just an afterthought!
With s floor screed you do have a wet cementatious floor which requires to be cured for up to three weeks prior to the underfloor heating being used. Although this can vary depending on the product used.
A floating OSB Floor would have the advantage of not needing a drying period! But it would still require radiant heating for the room.
