It is currently Wed Jan 23, 2019 8:10 pm
 Post subject: Concrete fence posts
PostPosted: Thu Apr 19, 2018 11:01 am
Has thanked: 4 times
Hello.
I'm looking at fitting a 3ft fence with a 6" gravel board, the concrete post options seem to be aimed at burring the post 1/3 of the total fence length underground, the issue I have is does this mean if I add a 6" gravel board I have to use the next post size up which look to be (5ft9) on most suppliers, which would mean I have to either cut the posts down or place them deeper in the ground? or does the gravel board add support and not count towards the total fence height?
Thanks for your time.
Alf
 Post subject: Re: Concrete fence posts
PostPosted: Thu Apr 19, 2018 12:06 pm
Has thanked: 225 times
Been thanked: 172 times
For a three foot fence I'd say you'd be ok with buried slightly less but no less than a foot deep, the deeper the better. What style of panel are you fitting?
If solid deeper is better, if it has gaps then it should be ok.
For this message the author Ktuludays has received gratitude : Alf_Smith
PostPosted: Thu Apr 19, 2018 1:50 pm
Has thanked: 627 times
Been thanked: 1795 times
The depth is there because the wind resistance of the panel can take a lot of pressure at times so the deeper the foundation the better. You fence being shorter in height will create less of a wind resistance so with a goof concrete fill in the ground it should be okay. I usually pack a bit of rubble in with the mix to support the post as it goes off.
Painting with BIN
For this message the author dewaltdisney has received gratitude : Alf_Smith
PostPosted: Thu Apr 19, 2018 2:59 pm
Thanks, I think i'll stick with the shorter posts then considering the panels arn't solid and there's a good chunk of bushes either side to block the wind that will remain there.
