Page 1 of 1
[ 9 posts ] |
| Author |
Message |
ozni
Posted: Thu Jul 16, 2009 6:08 am |
| Newly registered Member |
Joined: Wed Jul 15, 2009 3:54 pm Posts: 6 Has thanked: 0 times Been thanked: 0 times
Read lots of info on the forum. Great. I've just installed a new above cupboard basin using flexibile and compression joints. All well - so far. Just one concern I've only managed to turn the nut on the compression joint one quarter of a turn after being hand tight. Is this enough? Bit of resistence in terms of that squealing noise if you see what I mean, so I stopped shortly after that point. My previous experience of plumbing was a disaster (the days of going to Great Miles DIY and over tightening joints with little confidence in them staying on if not water tight! Swore that I would never again touch plumbing.
| Top |
Tec
Posted: Thu Jul 16, 2009 7:35 am |
Joined: Fri Jun 19, 2009 6:24 pm Posts: 56 Location: Holyhead Has thanked: 0 times Been thanked: 0 times
Ho Ozni,
What type of compression fitting is it? Also, is it on a gravity fed distribution pipe or mains? Whilst it is important not to over tighten compression fittings, if not enough then you could get an unpleasant surprise when turning the supply back on. If you 'nipped it up' then gave another half turn it should be okay, but get someone to check as you turn on the supply so you can always switch back off. There may just be a slight seepage requiring a further nip with a spanner...
BTW you said you only managed to turn "the nut" half a turn what's on the other end of the fitting? If it's a tap-connector it's not compression, but don't forget the fibre/rubber washer or it will leak...
Good luck!
Tec
| Top |
register or
log in
gas4you
Posted: Thu Jul 16, 2009 8:34 am |
| Senior Member |
Joined: Mon Apr 13, 2009 8:03 pm Posts: 3574 Has thanked: 51 times Been thanked: 230 times
What you've done is near enough text book.
Are there any drips when you turn the water on? If not don't worry.
It is always best to slightly under tighten, get a slight drip, then turn another 1/2 turn rather than over tighten in the first place.
_________________ Dave
www.drlgas.co.uk
| Top |
register or
log in
thescruff
Posted: Thu Jul 16, 2009 10:36 am |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39971 Has thanked: 187 times Been thanked: 2110 times
Cheap fittings.
What you need to do is lubricate the thread with a jointing compound, at the same time put some around the olive.
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
ozni
Posted: Thu Jul 16, 2009 12:39 pm |
Thanks for the replies. Appreciated. Its a mains sytem with no headert tank. The compression fitting is a 90 degree elbow (Conetite brand made by Ryemetal). Its attached to a 15mm copper pipe via the compression fitting and flexabile tap connector on the other side of the elbow using the nut and washer on the braided hose. No leaks/seepage so far. From what you guys say would I now be better to leave the hand tight plus one quarter of a turn tightness that I've done with spanners?
| Top |
register or
log in
thescruff
Posted: Thu Jul 16, 2009 12:43 pm |
| OAP |
In my opinion a 1/4 turn tightness is not good enough.
As I said cheap fittings needs the thread lubricated, or they don't tighten up properly.
| Top |
register or
log in
ozni
Posted: Thu Jul 16, 2009 1:02 pm |
Thanks for that thescruff. Just been looking at the olives andthe ones I've got are very different from the ones I used before. They are cone shaped would that make a difference. Attached image. Cheers [/img]
| Top |
register or
log in
ozni
Posted: Thu Jul 16, 2009 1:07 pm |
Image upload didn't work last post. Here goes again.
| Attachments: |
| Top |
register or
log in
thescruff
Posted: Thu Jul 16, 2009 1:16 pm |
| OAP |
None at all.
| Top |
register or
log in
Page 1 of 1
[ 9 posts ] |
