-> Plumbing Forum |
| Author |
Message |
GDP220 Junior Member
Posted: Thu Oct 02, 2008 1:25 pm Post subject: Compression joint on gas pipe under floorboard |
Hi there,
sorry if this has been covered already:
What i want to move the gas pipe for the cooker about 2 meters to the side because we are having a double doorway fitted in the kithen by the builder and the cooker is in the way at present.
So is it acceptable to use compression joints in the void under the floorboards, running the pipe parralell with the joist then back up through the floorboard?
It will be accessable if you lift the floorboards, they are cut at that area anyway and are only about 50cm long and the floorboards won't be covered i.e with carpet or tiles etc. It will only be temporary for a month or two as we are getting a new cooker installed along with a new kitchen, but we would still like to be able to use the cooker until then.
thanks in advance for advice.
GDP220 |
| Back to top |
thescruff Senior Member
Posted: Thu Oct 02, 2008 1:58 pm Post subject: |
No you cannot use compression fittings under the floor. _________________ Scruff |
| Back to top |
Posted: Thu Oct 02, 2008 2:11 pm Post subject: |
Thanks for the reply.
OK, thats a no go then.
How about if i just used a compression end cap to cap it off above the floorboard for now?
And we live off micro'd grub for a few weeks!!
ta again. |
| Back to top |
Posted: Thu Oct 02, 2008 2:23 pm Post subject: |
Yes that's ok, although I would have thought an rgi to move the pipe would be practical. _________________ Scruff |
| Back to top |
Posted: Thu Oct 02, 2008 2:34 pm Post subject: |
ta Scruff.
Yes, we know where the new cooker is to go so will do as you say and get a rgi to move the pipe to there, and connect the old cooker for now. It's just the builder rang to say he's coming 2moro (friday)! Wasn't expecting him till nxt wk, so may not get an installer to come stragiht away. Luckily, the pipe isn't actually in the way of where he'll be cutting the gap for the doors, so I should be able to just pull the cooker forward a bit. He'll be cutting from the other side. See what he says when he get here. If it's a prob, we'll egt the gas sorted b4 he does that side.
Thanks again for your help. Top work, and faster than a plumber's lad on a mobile! |
| Back to top |
EJJ150847 Senior Member
Joined: 04 Jan 2008 Posts: 1451 Location: Fareham, Hampshire
Posted: Thu Oct 02, 2008 2:56 pm Post subject: |
| GDP220 wrote: |
ta Scruff.
He was a plumbers lad in the '90's
1890's
John _________________ Mebyon Kernow |
| Back to top |
Hoovie Devon DIYer
Posted: Thu Oct 02, 2008 3:15 pm Post subject: |
you are cruel, John He was not a Plumbers lad in the 1890's
He was a full blown apprentice by then  _________________ I went to a bookstore and asked the saleswoman, "Where's the self-help section?"
She said if she told me, it would defeat the purpose. |
| Back to top |
Posted: Thu Oct 02, 2008 3:17 pm Post subject: |
Nov 29th 1958 actually  _________________ Scruff |
| Back to top |
Steve the Gas Senior Member
Joined: 30 May 2008 Posts: 794 Location: Notts/Derbys
Posted: Fri Oct 03, 2008 4:17 am Post subject: |
| Back to top |
