It is currently Mon Jul 16, 2018 7:56 am
 Post subject: Cold water pressure
PostPosted: Sun Jul 23, 2017 12:54 pm
Been thanked: 1 times
I am inept at anything DIY although I insist on having a go...
Could anyone help with the below???
I changed the upstairs bath taps. To do this I needed to turn off the mains feed to the house. Which meant I drained the loft tank. The cold tap had no pressure so I attached a hose to the hot to the cold. I then turned on the hot which seemed to clear the air lock partially, now I have some pressure although not as strong as before.
How do I resolve the water pressure? Could it still be an airlock if so how best to clear it? Or could it be a blocked pipe from where I drained the tank?
Struggling and getting it in the ear...
Thanks in advance
Cheers
Jeweller
 Post subject: Re: Cold water pressure
PostPosted: Sun Jul 23, 2017 7:13 pm
Has thanked: 3 times
Been thanked: 92 times
:dunno:
Could you have fitted high pressure taps in error?
PostPosted: Sun Jul 23, 2017 8:04 pm
Has thanked: 397 times
Been thanked: 1404 times
Notch1 wrote:
:dunno:
..........or taps with a narrow bore flexi hose
PostPosted: Sun Jul 23, 2017 10:04 pm
Has thanked: 174 times
Been thanked: 238 times
Is it just the new bath taps that have poor flow, or other taps too (such as washbasins, etc)?
PostPosted: Wed Jul 26, 2017 7:59 pm
Pressure rubbish in wash basin. The taps are the same just newer!
Thanks for your responses.
PostPosted: Wed Jul 26, 2017 9:43 pm
Right-o! It's definitely an airlock then. When you connected the hot and cold together to clear the airlock, I take it it was a mains pressure cold tap you used (usually kitchen sink) as connecting a cold tap that's fed from the tank wouldn't do the trick. Airlocks can be a bit of pain -- you might want to try running a hose from the kitchen cold tap to each of the bath taps. That ought to do it.
Or, if you happen to own a wet vac, then you can put the nozzle over each bath tap in turn, and literally suck the air (and probably a few litres of water) out of the pipework. Obviously don't do that if you have a normal (dry) vaccuum cleaner unless you want it to go bang!
For this message the author chrrris has received gratitude : multiman
PostPosted: Tue Aug 01, 2017 8:33 pm
chrrris wrote:
Right-o! It's definitely an airlock then. When you connected the hot and cold together to clear the airlock, I take it it was a mains pressure cold tap you used (usually kitchen sink) as connecting a cold tap that's fed from the tank wouldn't do the trick. Airlocks can be a bit of pain -- you might want to try running a hose from the kitchen cold ki tap to each of the bath taps. That ought to do it.
Turner the combi boiler off, ran a hose from hot tap which is mains through cold tap which seems to have cleared it!
Thanks all
For this message the author Jeweller has received gratitude : multiman
PostPosted: Wed Aug 02, 2017 12:50 am
Thanks all
Well done. Glad you've got it sorted. Sounds like you have mains-pressure hot water via the combi and an old tank-fed cold system. When you're next feeling brave, I would be inclined to ditch the cistern in the loft and have the whole house hot+cold at mains pressure. Then you can say goodbye to airlocks for good!
