Ultimate Handyman Home
Cold water on sealed system
Goto page 1, 2  Next
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum
jonifresh2008
Junior Member
PostPosted: Wed Mar 19, 2008 7:14 am    Post subject: Cold water on sealed system Add User to Ignore List Reply with quote
Is it ok to run the keep the central heating running on a combi boiler while the main cold water feed is temperary turned off to change a tap.
Back to top
PostPosted: Wed Mar 19, 2008 7:18 am    Post subject: Add User to Ignore List Reply with quote
Yes, that should not be a problem at all.
When you restore the mains water make sure you open the cold taps in the hose first, incase a slug of dirty water is released when you open the stop tap. This way it will not get into the combi Wink
DIY | DIY Video
Back to top
jonifresh2008
Junior Member
PostPosted: Wed Mar 19, 2008 8:22 am    Post subject: Add User to Ignore List Reply with quote
Thanks for your help.
Back to top
thescruff
PostPosted: Wed Mar 19, 2008 10:50 am    Post subject: Add User to Ignore List Reply with quote
You sure about that bossman, I don't think I would be happy.
What boiler is it
Back to top
PostPosted: Wed Mar 19, 2008 5:09 pm    Post subject: Add User to Ignore List Reply with quote
What boiler is it
Why would you not be happy?
DIY | DIY Video
Back to top
thescruff
PostPosted: Wed Mar 19, 2008 5:43 pm    Post subject: Add User to Ignore List Reply with quote
ultimatehandyman wrote:
What boiler is it
I don't know, and I'm too busy today to check Shocked
Combi boilers don't like it if they're running on empty, and I can imagine all sorts of nasty's going on.
If you turn the mains off and open the hot tap to change it, will the diverter valve stick in the hot water mode, and overheat.
Just didn't sound like a good idea. and it still don't, perhaps one of the others can comment
Back to top
gasspark
PostPosted: Wed Mar 19, 2008 5:53 pm    Post subject: Add User to Ignore List Reply with quote
What boiler is it
A combi is a sealed system, so is not affected when the water mains is turned off, there just will be no hot water. The UHM's advise is fine.
If you have the skill abuse it if you want the skill learn it.
Back to top
thescruff
PostPosted: Wed Mar 19, 2008 5:58 pm    Post subject: Add User to Ignore List Reply with quote
But what will happen when you drain the plate heat ex out.
I know you can turn the water off
Back to top
PostPosted: Wed Mar 19, 2008 6:01 pm    Post subject: Add User to Ignore List Reply with quote
scratch
Drain what Confused
He just said he wanted to change a tap washer Confused
DIY | DIY Video
Back to top
gasspark
PostPosted: Wed Mar 19, 2008 6:10 pm    Post subject: Add User to Ignore List Reply with quote
You can still change the tap with the heating on the plate heat exchanger will just be empty the heating circuit that passes through the PHE cannot affect the DHW circuit.
Back to top
scoobydoo
Junior Member
PostPosted: Sun Mar 23, 2008 12:53 pm    Post subject: combi Add User to Ignore List Reply with quote
I think scruffs lost the plot,no problem with turning mains off Thumbright
th eyes have it all
Back to top
thescruff
PostPosted: Sun Mar 23, 2008 1:15 pm    Post subject: Re: combi Add User to Ignore List Reply with quote
Are you a member of the Kennel Club Scoobydoo Laughing
Suppose there was no local isolating valves on the taps, then the secondary water in the boiler will drain out.
There is the possibility the diverter valve will stay in the DHW position.
Some combi's have a tube in the primary heat exchanger for DHW, with no water init would could/will damage it
Scruff
Back to top
gasspark
PostPosted: Tue Mar 25, 2008 5:42 pm    Post subject: Re: combi Add User to Ignore List Reply with quote
The boiler has its own isolation valve, so it does'nt matter if the tap does not, he stated he's changing the hot tap so isolsting the inlet to the boiler he is isolating all dhw taps
The diverter works with a differential between positive and negitive pressures, it requires water flow to be able to make a DHW demand
The tube is not on the heat exchanger but on the outlet pipework of the exchanger and is connected to the negitive side of the diverter valve. But understand where you'r coming from, if the diverter was directing the heating circuit around the boiler only, then there would be a problem if the overheat stat was knacked, would could/will damage boiler, but the chance of the diverter being in that position with the water off would be very rare and for the overheat stat knacked as well even rarer, but technically possible.
Back to top
thescruff
PostPosted: Tue Mar 25, 2008 5:52 pm    Post subject: Add User to Ignore List Reply with quote
Thank you Gasspark, for explaining that.
As I said I wasn't sure and small domestic boiler are not my line, I could see a potential problem and voiced an opinion.
Scruff
Back to top
gasspark
PostPosted: Tue Mar 25, 2008 7:32 pm    Post subject: Add User to Ignore List Reply with quote
No probs, sorted
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum All times are GMT
Goto page 1, 2  Next
Page 1 of 2
