Ultimate Handyman Home
cold storage tank overflowing
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers
bedspoolplayer
Junior Member
PostPosted: Sat Dec 01, 2007 9:16 pm    Post subject: cold storage tank overflowing Add User to Ignore List Reply with quote
got b/boiler gravity hot water pumped heating got problem where c/storage tank in loft is overflowing change ballvalve not that but found water is going up the cold feed pipe fron cylinder up into c/storage tank in loft both tanks on same level both ballvalves are not runing only when water is draw off anyone got any clures pls hope this is in right section new to site
Back to top
Hinton Heating
Gas/Heating Expert
PostPosted: Sat Dec 01, 2007 9:25 pm    Post subject: Add User to Ignore List Reply with quote
perhaps a mixer tap is passing cold mains into the hot pipe, and up to cold water tank
is the water warm in tank?
www.hintonheating.com
Back to top
bedspoolplayer
Junior Member
PostPosted: Sat Dec 01, 2007 9:37 pm    Post subject: Add User to Ignore List Reply with quote
hi yes its got the chill off it got mixer tap kitchen two w/valves basin got pair of taps got no bath got shower with bristan mixer valve would it be possible to fit non return valves or not or how can i find out which one it is pls
Back to top
Hinton Heating
Gas/Heating Expert
PostPosted: Sat Dec 01, 2007 9:43 pm    Post subject: Add User to Ignore List Reply with quote
you need to isolate the shower, washing machine, and any other mixers to find out which is faulty, rather than hiding the problem with a non return valve
Back to top
bedspoolplayer
Junior Member
PostPosted: Sat Dec 01, 2007 9:46 pm    Post subject: Add User to Ignore List Reply with quote
ok cheers for that will do the kitchen tap is a deck miser and is leaking from the centre swivel outlet could it be this pls
Back to top
Hinton Heating
Gas/Heating Expert
PostPosted: Sat Dec 01, 2007 9:50 pm    Post subject: Add User to Ignore List Reply with quote
yep, it could well be.
i would think the shower is tank fed, rather than from the mains from the cold.
you could try running the hot in kitchen mixer, until pipe is hot, then feel the pipe, once you turn it off, see how quick it goes cold.
if its only a few seconds, then that'll show the cold mains is going into the hot pipe
Back to top
bedspoolplayer
Junior Member
PostPosted: Sat Dec 01, 2007 9:53 pm    Post subject: Add User to Ignore List Reply with quote
ok ty for that give me a headache lol will try tomm many thanks
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers All times are GMT
Page 1 of 1
