| Author |
Message |
Ant 1808
Posted: Wed Nov 30, 2011 4:30 pm |
| Newly registered Member |
Joined: Mon Nov 29, 2010 1:54 am Posts: 40 Has thanked: 6 times Been thanked: 0 times
It filled up hot water from the return pipe, half the radiatior - but pipe still cold and doesn't appear to be anything coming through the thermostat valve???
| Top |
thescruff
Posted: Wed Nov 30, 2011 4:41 pm |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39971 Has thanked: 187 times Been thanked: 2110 times
Only way you can test it, is to remove the rad and run water through the valve, preferably using a hose pipe as per my earlier post.
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
Ant 1808
Posted: Thu Dec 01, 2011 2:31 pm |
Hi Scruff. I have tried the above and still can't get any wather through. Should I try replacing the valve??
| Top |
register or
log in
thescruff
Posted: Thu Dec 01, 2011 2:35 pm |
| OAP |
If you have the valve disconnected from the rad and no water, then a new valve would be the order.
Have you tried lifting the pin 2-3mm with grips, and do remember if it pots up water will shoot out, so you should have a hose connected.
| Top |
register or
log in
Ant 1808
Posted: Thu Dec 01, 2011 2:41 pm |
I have tried lifting the pin and still nothing. As long as the heating is switched off and the radiator empty, can I replace the valve without water gushing out the infeed pipe??
| Top |
register or
log in
thescruff
Posted: Thu Dec 01, 2011 4:17 pm |
| OAP |
Best to drain down or at least take the pressure down to zero, and snatch change it. After the carpets are secured.
| Top |
register or
log in
Ant 1808
Posted: Thu Dec 01, 2011 4:54 pm |
Drain down the whole system??
| Top |
register or
log in
thescruff
Posted: Thu Dec 01, 2011 5:02 pm |
| OAP |
To be safe yes. A pro would take the pressure off the system and snatch it as said, but you could get wet if it goes belly up.
| Top |
register or
log in
Ant 1808
Posted: Thu Dec 01, 2011 7:16 pm |
I'm going to ask a silly question now, if I try and change without draining, I'm likely to get flooded???!! Think I know the answer, but need to ask. Its a conventional gravity fed boiler with tank in the loft. And do you think I'm better getting a pro to do it?
| Top |
register or
log in
thescruff
Posted: Thu Dec 01, 2011 7:22 pm |
| OAP |
Shucks it's a simple as ABC job.
As I said just remember to protect everything, and take your time.
| Top |
register or
log in
Ant 1808
Posted: Thu Dec 01, 2011 7:25 pm |
Thanks - I'll give it a go
| Top |
register or
log in
thescruff
Posted: Thu Dec 01, 2011 7:28 pm |
| OAP |
Better say if you do snatch it, remember to turn the decorators cap down so you can't blow through the valve.
Have the new valve ready, Hold the valve tight in one hand and undo the nut holding it on the pipe, all you do then is swap them over as quick as you like.
| Top |
register or
log in
Ant 1808
Posted: Thu Dec 01, 2011 7:46 pm |
| Top |
register or
log in
thescruff
Posted: Thu Dec 01, 2011 7:53 pm |
| OAP |
When you get the valve it will have a cap so you can manually turn the valve off.
Go for the same valve as existing.
| Top |
register or
log in
Ant 1808
Posted: Thu Dec 01, 2011 7:54 pm |
| Top |
register or
log in
