It is currently Wed May 23, 2012 4:26 am
 Post subject: Cold pumped shower
PostPosted: Thu Nov 17, 2011 6:37 pm
Has thanked: 1 times
I have a pumped thermostatic shower but the shower will not get hot enough after a pump change.
Could the surrey valve be restricted?
As the feed to the pump feels much colder than the feed for the rest of the hot taps?
Any thoughts or advice
Dave
 Post subject: Re: Cold pumped shower
PostPosted: Thu Nov 17, 2011 7:14 pm
Has thanked: 57 times
Been thanked: 99 times
Well lets assume it is related to pump replacement,so could be maybe a air lock,a valve that has not opened up fully,rubbish in the filter to pump or shower valve
If you have found help on the UHM's forums,why not help out the UHM's Nominated Charity,find out more here
PostPosted: Thu Nov 17, 2011 7:24 pm
Hi
All the valves are open and the filters are clean i checked them
I just feels like the water coming from the surrey valve is not as hot as it should be
The valves are new when the pump was fitted
I am going to get a temp gauge on it when i can and see what the temp readings are
Dave
PostPosted: Thu Nov 17, 2011 7:44 pm
Has thanked: 76 times
Been thanked: 372 times
I take it both sides are pumped and the cold isn't off the mains?
PostPosted: Thu Nov 17, 2011 8:18 pm
Hi
Yeah both sides are pumped cold it off the header tank in the loft
Dave
PostPosted: Mon Nov 21, 2011 3:38 pm
All sorted
It was the thermostat in the shower control valve Adjusted and now nice and hot again :huray:
Dave
Users browsing this forum: No registered users and 6 guests
