It is currently Fri Feb 22, 2019 12:09 am
 Post subject: Cleaning power tools
PostPosted: Sat Sep 08, 2007 9:48 pm
Borders Bodger
Been thanked: 4 times
My tools are getting in a sorry state with the sawn dust clagging up a circular saw in particular (wood, MDF & Aquapanel most recently)- I was planning a bit of a clean up session and lubrication with 3-in-1 oil.
Before I do this, just thought I would get a quick check of if anyone sees any problem with this or if there are any other more suitable products?
Cheers,
Hoovie :thumbright:
 Post subject:
PostPosted: Sat Sep 08, 2007 11:16 pm
Has thanked: 702 times
Been thanked: 2027 times
wd40 penetrates better
you can try spraying with ptfe spray to aid cutting and help stop build up of resin ect
http://www.screwfix.com/search.do;jsess ... ptfe+spray
 Post subject:
PostPosted: Sun Sep 09, 2007 7:36 am
Borders Bodger
Thanks, Big-all - good tip :thumbright:
 Post subject:
PostPosted: Sun Sep 09, 2007 11:08 am
Has thanked: 643 times
Been thanked: 1816 times
I use compressed air to blast the dust out. This clears most stuff away. I then use kitchen towel soaked in WD40 and give them a wipe over. Now the damp weather approached it is a good time to give everything a wipe with WD40.
 Post subject:
PostPosted: Sun Sep 09, 2007 4:01 pm
Has thanked: 105 times
Been thanked: 358 times
Give them a good blow through with an airline.
If theres a lot or resin around router cits, saw blades etc, i believe oven cleaner works well. :thumbright:
 Post subject:
PostPosted: Sun Sep 09, 2007 5:54 pm
Borders Bodger
Wul;d I be right in thinking MDF is very resin 'rich'?
Has WD40 sort of replaced 3-in-1 as lubrication of choice - I thought if you apply a sheen of 3-in-1 or similar with a kitchen towel on a saw, then that keeps the rust away but WD40 tends to evaporate?
(maybe I am just showing my age and old fashioned ways :lol: )
 Post subject:
PostPosted: Sun Sep 09, 2007 5:59 pm
There are many lubricates you can use to wipe and clean your gear with. Take the one that you like the best and use. If you have a owners manual than read what they have to say.
 Post subject:
PostPosted: Sun Sep 09, 2007 6:23 pm
If your looking for something to keep moisture at bay, there are sprays designed just for protecting tools.
Rocol do a range, but its not cheap. There are a few others about.
 Post subject:
PostPosted: Sun Sep 09, 2007 8:58 pm
Has thanked: 7 times
Been thanked: 9 times
I once used sprayed a whole can of WD40 into the engine bay of my clio, electrics mostly but no one told me not to spray the manifold (It looked rusty!) Next time I started her up there was white smoke comming through the air vents and enveloping the car....but she always started first time!
Don't buy a dwarf with learning difficulties,
It's not big and it's not clever.
 Post subject:
PostPosted: Sun Sep 09, 2007 11:15 pm
Been thanked: 1 times
dont spray oil in the motor it will make the dust stick
use pfte on the bases to lubricate
and resin cleaner to remove resin
both avaliable from sfx
 Post subject:
PostPosted: Mon Sep 10, 2007 8:20 am
Borders Bodger
yup - both ordered ready for cleanup :wink: - and not bad prices either, got to be worth doing :thumbright:
Cheers
Hoovie.
 Post subject:
PostPosted: Sat Sep 29, 2007 1:45 pm
Borders Bodger
tried to use a Ryobi Circular saw I got 2nd hand on ebay to cut a 4' length of marine ply today - kept jamming up - sprayed the PTFE on the blade and tried again - perfect!
Cheers Tim :thumbright:
