Ultimate Handyman Home
Cleaning brickwork
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum
johnch
Junior Member
PostPosted: Tue Jun 12, 2007 5:38 am    Post subject: Cleaning brickwork Add User to Ignore List Reply with quote
I need to clean some brickwork (house wall) that has been splashed with white paint (not by me!) - any suggestions ? I have tried brick acid, but this hasn't really helped ...
Back to top
leebwk
PostPosted: Tue Jun 12, 2007 7:08 am    Post subject: Add User to Ignore List Reply with quote
Hi Johnch,
Brick acid won't help as it only attacks/dissolves alkali which is the main component in cement. i would try nitromors and maybe a soft wire brush.
Unfortunately some paints soak into the brick and is very hard to remove without damaging the brick face.
Hope this helps.
What was the best thing before sliced bread?
Back to top
PostPosted: Tue Jun 12, 2007 8:11 am    Post subject: Add User to Ignore List Reply with quote
Was the paint water or oil based?
You could try using some brick cleaner with a pressure washer?
DIY | DIY Video
Back to top
johnch
Junior Member
PostPosted: Tue Jun 12, 2007 8:33 am    Post subject: Thanks ... and a couple of follow up questions Add User to Ignore List Reply with quote
OK - thanks very much. I'm not sure whether the paint was water or oil based (the stains were present when we moved into the house) - will try your suggestions. A couple of ignorant questions (!) - 1) what is nitromors ? 2) can you recommend a decent brick cleaner ?
Cheers - johnch
Back to top
PostPosted: Tue Jun 12, 2007 8:39 am    Post subject: Add User to Ignore List Reply with quote
Nitromors is a paint remover, which is most commonly used to strip paint from wood etc.
http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=101350&ts=37529&id=45227
I was thinking of something like this-
http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=101757&ts=37455&id=74817
or perhaps this-
http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=101757&ts=37487&id=45293
Hope this helps
DIY | DIY Video
Back to top
johnch
Junior Member
PostPosted: Tue Jun 12, 2007 11:25 am    Post subject: Thanks again. Add User to Ignore List Reply with quote
Thanks again - good timing as I was heading to Screwfix tonight on my way home. Cheers ...
Back to top
moon133
PostPosted: Tue Jun 12, 2007 12:02 pm    Post subject: Add User to Ignore List Reply with quote
If you're going to be using Nitromors, with a wire brush, use a full face cover, and rubber gloves, and cover the rest of yourself with old clothes. If you flick nitro on you skin when scrubing with a wire brush, you won't notice until about a minute after when it starts to burn, and I can;t imagine the damage it'll do if you get it in your eyes.
If you can't do a full face shield, do saftey goggles at the very least.
Mummy said I was special!
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum All times are GMT
Page 1 of 1
