Page 1 of 1
[ 10 posts ] |
| Author |
Message |
Mooncat
Posted: Thu Jul 16, 2009 7:46 pm |
| Senior Member |
Joined: Sun Dec 23, 2007 4:11 pm Posts: 9924 Location: Wales Has thanked: 33 times Been thanked: 42 times
A collection of bits to assemble into a float valve, where can I find a diagram to put it together? Modern plastic type with a large rubber diaphragm.
_________________ I started out with nothing, I still have most of it. Directmail scam information site: http://astrocat.proboards.com/index.cgi?
| Top |
thescruff
Posted: Thu Jul 16, 2009 8:14 pm |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39971 Has thanked: 187 times Been thanked: 2110 times
Pic of the bits perhaps.
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
Mooncat
Posted: Thu Jul 16, 2009 9:15 pm |
| Senior Member |
Picture as requested. Left it large so you can zoom in. Float has "Macdee" on it, other bits no identification.
| Top |
register or
log in
WARDS
Posted: Thu Jul 16, 2009 9:27 pm |
| Senior Member |
Joined: Thu Apr 16, 2009 4:27 pm Posts: 103 Location: PELSALL Has thanked: 0 times Been thanked: 0 times
| Top |
register or
log in
thescruff
Posted: Thu Jul 16, 2009 11:28 pm |
| OAP |
That's the order it goes then it fits inside the big plastic bit, the white bit goes through the hole in the valve, the washer sits on the flat end, the nozzle fits the other side of the washer, and the little fibre washer seals it.
Don't know what that little red bit is, but should be obvious I think.
You have a white nozzle for high pressure, and a red one for low.
| Attachments: |
| Top |
register or
log in
thescruff
Posted: Thu Jul 16, 2009 11:29 pm |
| OAP |
that was a complete failure  don't go away
| Top |
register or
log in
thescruff
Posted: Thu Jul 16, 2009 11:31 pm |
| OAP |
try again same instructions
| Attachments: |
| Top |
register or
log in
register or
log in
rio.
Posted: Fri Jul 17, 2009 5:01 pm |
| Senior Member |
Joined: Fri Nov 14, 2008 4:47 pm Posts: 1051 Location: surrey Has thanked: 0 times Been thanked: 5 times
the odd red bit is for securing the float to the arm, it looks like the float securing screw is missing, unless its on the float out of camera shot.
| Top |
register or
log in
jg
Posted: Sat Jul 18, 2009 11:34 am |
| Senior Member |
Joined: Fri Mar 13, 2009 8:32 am Posts: 743 Location: Bucks Has thanked: 15 times Been thanked: 43 times
I was looking for something like that diagram a couple of weeks ago. Thanks very much. I've just confirmed that I did figure it out correctly.
| Top |
register or
log in
Page 1 of 1
[ 10 posts ] |
