Ultimate Handyman Home
circular saw blades
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Carpentry/Joinery Forum
fin
PostPosted: Tue Aug 12, 2008 4:33 pm    Post subject: circular saw blades Add User to Ignore List Reply with quote
ok i obviously need a new blade in my circular. but for now will a spare blade from my chop saw do? or will i risk burning the machine out?
saw is an elu with 216mm diameter blade. the spare blade is from my 701 chop saw and is a series 60 dewalt blade with a negative rake design
the blade that was in my circular is totally goosed
Back to top
chippymike
PostPosted: Tue Aug 12, 2008 8:09 pm    Post subject: Add User to Ignore List Reply with quote
wouldn't bother mate get yourself a new trend blade or freud blade
Back to top
View user's profile Send private message MSN Messenger
fin
PostPosted: Tue Aug 12, 2008 8:37 pm    Post subject: Add User to Ignore List Reply with quote
ok ta for the advice. actually the blade i took out the machine is a negative rake design aswell having compared the 3 i have there all like that. cutting performance was pretty crap. guess its due to the blade design partially. ill sort a new blade for it asap
Back to top
Griffin
Junior Member
PostPosted: Fri Aug 29, 2008 12:48 am    Post subject: Add User to Ignore List Reply with quote
It could just be that your blades need sharpening, check for burning on the sides of the teeth. Negative rake blades are those multi material type blades you can use on wood and aluminum, generally they aren't as good in timber as a positive raked blades.
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Carpentry/Joinery Forum All times are GMT
Page 1 of 1
