-> Carpentry/Joinery Forum |
| Author |
Message |
Jaeger_S2k Senior Member
Joined: 19 Nov 2006 Posts: 2786 Location: North West, England, United Kingdom
Posted: Tue Aug 21, 2007 3:26 pm Post subject: CHISEL HELP!!! Should they stay or should they go? |
Guys, Guys.
Picked up a load of various tools with other bits and pieces and I found some Chisels amongst other things.
I've just been to the flat (the back door lock had jammed locked) and replaced the lock, required some adjustment to the holes so had to do some chiselling! Used my plastic handled Stanleys which did OK but they've been abused (by a bad man) and they where never really very good in the first place. Now I've got these 'other' chisels I don't know what to do?
Question should I keep these guys as they've not cost a lot or should I just suffer my Stanleys and let these go to a 'better' home?
I know nothing about chisel makes other than Marples and Sorby are thought to be reasonable makes.
Your advice and what would you do with these would be appreciated.
2 Colonel Wood Chisels
Chisel No 1.
Length - 11"
Width - 3/16"
Chisel No 2.
Length - 10 3/4"
Width - 1/2"
2 Marples Chisels 1 GIANT! 1 Smaller
Marples Chisel No 1. Length - 16" Width - 1 1/2"
Marples Chisel No 2. Length - 9" Width - 5/8"
4 Sorby Wood Chisels
Sorby Chisel No 1. Length - 9.5" Width - 5/8"
Sorby Chisel No 2. Length - 10" Width - 3/4"
Sorby Chisel No 3. Length - 9.5" Width - 3./4"
Sorby Chisel No 4. Length - 10" Width - 3/8"
Hearnshaw "John Bull" Mortice Chisel Length - 12" Width - 1/4"
 _________________ Jaeger.
FSBF |
| Back to top |
big-all Pro Carpenter
Joined: 16 Dec 2006 Posts: 2775 Location: redhill surrey an auld reekie laddie
Posted: Tue Aug 21, 2007 4:30 pm Post subject: |
you can use wooden chisels with metal rings at the top of the chisel and a hammer
but in general the rule of thumb is metal on plastic or wood on wood[mallet]
so keeping that in mind do you want to carry a wooden mallet around :grin: _________________ we are all ------------------still learning |
| Back to top |
carhartt kid Senior Member
Posted: Tue Aug 21, 2007 8:33 pm Post subject: |
You know that they're valuable, especially the John Bull. You're just showing off mate????????? I'd stick em all on e-bay and sell them. You probably get 60-80 if they're all sold as a bundle! _________________ http://www.carhartt.com/ |
| Back to top |
Posted: Tue Aug 21, 2007 11:02 pm Post subject: |
No carhartt I didn't.
So sling them on ebay and buy a plastic set of Marples that I can hit with a hammer? :o
Oh bugger, what to do?
Anyone on here wants to buy let me know. _________________ Jaeger.
FSBF |
| Back to top |
handimick Junior Member
Joined: 19 Aug 2007 Posts: 26 Location: Wolverhampton
Posted: Wed Aug 22, 2007 6:40 pm Post subject: |
Would`nt swap my marples for the world??? :grin: _________________ Tea, milk and no sugar... |
| Back to top |
Scrit Pro Cabinetmaker
Joined: 27 Dec 2005 Posts: 394 Location: The Sunny Pennines
Posted: Sat Aug 25, 2007 10:37 am Post subject: |
| carhartt kid wrote: |
| You probably get 60-80 if they're all sold as a bundle! |
B*ll*x! There is a common misconception that old = high value. Several of these chisels are well used (#4, 6 and 7) and have probably been ground to the end of their tool steel sections (older blades were made by hot forging a tool steel edge piece onto a lower grade steel backing piece). Some of them also show signs of abuse by amateurs, after all what kind of numpty uses a hammer to drive a chisel? I'd suggest cleaning them up, sharpening them and trying to use them. The better ones (#1, 2, 5 and 8) are probably worth £2 to £5 each, the socketed Marples (#3) might fetch a tenner and the Hearnshaw oval bolstered mortise chisel (#9) is probably in the £6 to £10 area as well.
Scrit _________________ Measure twice, cut once - except fingers! |
| Back to top |
Posted: Mon Aug 27, 2007 4:01 pm Post subject: Re: CHISEL HELP!!! Should they stay or should they go? |
Update
2 Marples Chisels 1 GIANT! 1 Smaller Pair Sold - £23.00
4 Sorby Wood Chisels. Sold - 99p
Hearnshaw "John Bull" Mortice Chisel Length - 12" Width - 1/4" Sold - £4.75 _________________ Jaeger.
FSBF |
| Back to top |
