-> Building Forum |
| Author |
Message |
Chris von Mole Junior Member
Posted: Sat Jul 19, 2008 7:40 pm Post subject: Chimney breast widths not equal |
Hello,
I live in an Edwardian terrace circa 1910.
I've noticed that the chimney breast in my front bedroom is about 6inches wider than the one in the room directly below it. Is this normal?
(I'm contemplating building a wardrobe into the alcoves of the upstairs room, and could do with the extra space if the breast has been artificially widened, say with plaster board etc ).
I could of course drill a few test holes to find out, but thought I'd ask whether this is normal first!
Thanks for your help,
Chris |
| Back to top |
big-all Pro Carpenter
Joined: 16 Dec 2006 Posts: 2775 Location: redhill surrey an auld reekie laddie
Posted: Sat Jul 19, 2008 8:13 pm Post subject: |
each chimnie has its own flue so the fire down stairs has to pass the up stairs fire somewhere!!!! _________________ we are all ------------------still learning |
| Back to top |
leebwk Senior Member
Posted: Tue Jul 22, 2008 7:07 am Post subject: |
yes this is normal your flue probably turns as is normally the case and the breast has been built to compensate for this _________________ What was the best thing before sliced bread? |
| Back to top |
Posted: Thu Jul 24, 2008 10:01 pm Post subject: |
Thanks for your comments.
However, I've just measured the chimney breasts in the back bedroom and corresponding downstairs room and discovered that the breast is narrower upstairs! Confusing !
Maybe I should pluck up the courage to ask my neighbour (who I don't know very well) if she can let me know her breast measurements!!
Chris |
| Back to top |
Wood Magnet Senior Member
Posted: Fri Jul 25, 2008 3:38 am Post subject: |
 _________________ People forget how fast you did a job - but they remember how well you did it.
I no longer skinny dip, i chunky dunk these day's. |
| Back to top |
Hoovie Devon DIYer
Posted: Fri Jul 25, 2008 7:10 am Post subject: |
| Chris von Mole wrote: |
Chris |
You also mentioned a test drilling?
 _________________ I went to a bookstore and asked the saleswoman, "Where's the self-help section?"
She said if she told me, it would defeat the purpose. |
| Back to top |
Posted: Fri Jul 25, 2008 1:54 pm Post subject: |
oooer missus!  _________________ People forget how fast you did a job - but they remember how well you did it.
| Back to top |
Posted: Fri Jul 25, 2008 4:26 pm Post subject: |
another though
if its on a party wall and what your saying is the face off the stack is farther out from the wall on one side than the other by quite a lot perhaps 18"plus
this can be quite normal as the space on each side off the stack is full depth is dedicated to the different houses
in other words the cupboard/space extends slightly into your neibours on the one side and your nabours cupboard extends onto your property
this gives you both a large usefull space instead of 2 smaller spaces _________________ we are all ------------------still learning |
| Back to top |
