It is currently Wed May 23, 2012 3:48 am
PostPosted: Sun Dec 04, 2011 5:56 pm
Has thanked: 5 times
Hello everyone :wink:
I've been putting a curtain pole fixing direct to the plaster/brick on a 1930's house. The problem is that the existing hole for one rawlplug has been drilled so badly that no expansion fixing will hold. All the other 5 fixings are fine. I've been looking at using a chemical fixing as there would be no expansion forces in the hole, but this normally means that I'd have to put a stud into the wall first, then put the curtain pole bracket onto the stud with a nut/washer. This would work, but would look a bit 'clumsy'.
I've heard that Fischer do 'Fill and Fix', which I think means you can drive a screw straight into the chemical in the hole.
Has anyone used this or similar?
Any advice or help would be appreciated.
Thanks, samjmann.
PostPosted: Mon Dec 05, 2011 7:26 pm
Has thanked: 6 times
Been thanked: 108 times
I have in the past filled the hole with chemical resin, allow it to go off, then redrill and plug/screw as normal.
No problems.
For this message the author Hitch has received gratitude : samjmann
PostPosted: Mon Dec 05, 2011 8:59 pm
Hi
Thanks for the reply, Fischer's product looks good, but a bit pricey!
Regards, samjmann. :thumbright:
PostPosted: Mon Dec 05, 2011 11:22 pm
They are certainly not cheap, but they are good quality.
