It is currently Mon Jul 16, 2018 7:57 am
PostPosted: Mon Jul 17, 2017 3:56 pm
Been thanked: 1 times
i'm fitting a new kitchen and there are two 15mm copper pipes that run up the wall so i would like to chase them into the wall, i was thinking off wrapping the pipes with denso anti corrosion tape and then plastering over them, but a friend of mine suggested it might be better to use push fit poly pipe but i'm not sure i like the idea of plastic push fit pipes , any idea which way would be best.
PostPosted: Mon Jul 17, 2017 6:46 pm
Been thanked: 37 times
Either is OK, but make sure that:
1. The copper would need wrapping against corrosion as you plan. Any fittings should be soldered.
2. The plastic pipe would not need anti-corrosion wrapping. However, don't have any fittings buried, just a plain run of pipe. If either pipe is for central heating make sure you use barrier pipe (or just use it anyway).
3. Either would need some soft wrapping / air gap as well to allow for expansion and contraction, both hot and cold. Otherwise there is s risk of the plaster cracking off.
For this message the author andy48 has received gratitude : multiman
PostPosted: Wed Jul 19, 2017 8:31 pm
thanks, i think i'm going to try and cover the existing copper pipes ,i know push fit pipes are ok but i really don't like them we also have really high water pressure and i'm worried they might come apart.
