It is currently Wed Dec 19, 2018 9:51 am
PostPosted: Tue Oct 10, 2017 10:32 pm
Has thanked: 2 times
Hi, I currently have a halogen outdoor floodlight which is not working properly, so I need to replace it, I was thinking of replacing it with an LED floodlight, however, I don't have the first idea about electrics. If I disconnect the existing (halogen) light (after switching the power off of course), I believe I should find a positive, neutral and earth wire? On a halogen light I understand these would normally wire straight into a block inside the light, however, all the LED floodlights I have seen so far seem to have a cable attached, so my question is: Can I connect the existing wires (from the house) and the wires from the LED light into a junction box, is this the correct way to wire it, and is there a certain type of junction box I would need to use?
Apologies for the daft questions, I have never touched any house electrics before.
Any help would be much appreciated.
Thanks in advance.
PostPosted: Tue Oct 10, 2017 10:50 pm
Has thanked: 39 times
Been thanked: 1382 times
First of all its Live Neutral and Earth
I would suggest you look for a different flood light, have a look at screwfix Click here
As you are not sure, I would suggest if you really do want to DIY turn the main switch off on your consumers unit.
Or get some one else to show you how its done.
For this message the author someone-else has received gratitude : Roosterzfoot
PostPosted: Wed Oct 11, 2017 6:03 pm
Approved Electrician
Has thanked: 168 times
Been thanked: 582 times
:welcomeuhm:
The correct jb is something like
https://www.screwfix.com/p/jb/53068.
For this message the author OnlyMe has received gratitude : Roosterzfoot
PostPosted: Fri Oct 13, 2017 10:46 am
Has thanked: 696 times
Been thanked: 28 times
Too many factors most led come with wire already attached, I have opened and re wired but don't suggest unless you know what you are doing, is the junction box outside or Inside and can you use a multimeter ?
PostPosted: Fri Oct 13, 2017 9:12 pm
Thanks for your reply
I don't think there is a junction box at the moment, the existing halogen light is wired to a light switch indoors. What I was thinking was removing the old light, feeding the existing wires from the switch into a junction/connector box, and then the wires from the new led light also into the junction/connector box. Obviously I would flip the breaker and check with a voltage detector before starting. I have never used a multimeter.
PostPosted: Fri Oct 13, 2017 9:47 pm
It will be worth your while getting a multi meter, you would be surprised how use full they are, and they don't cost that much :wink:
PostPosted: Fri Oct 13, 2017 9:54 pm
