Ultimate Handyman Home
Central Heating working, hot water NOT working
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers
DIYNewbie
Junior Member
PostPosted: Sat Sep 08, 2007 9:02 am    Post subject: Central Heating working, hot water NOT working Add User to Ignore List Reply with quote
Problem:
My central heating (boiler/raditor) is working perfectly fine, but the boiler does not fire up for hot water at all.
History of Problem:
I moved into a house recently. When I started hot water using the electronic timer thingy, the boiler fired up and I got some hot water. The water however was not as hot as it should have been i.e. the thermostat was set at 60 degrees and I was getting about 30-35 degrees. After 4 days the boiler refuses to fire up for hot water. However, it works fine for central heating.
Any clues about what could be wrong?
Is it thermostat or something else?
Many Thanks !
Back to top
chef
UHM Super Moderator
PostPosted: Sat Sep 08, 2007 9:07 am    Post subject: Add User to Ignore List Reply with quote
Duplicate post deleted from Plumbing Thumbright
Back to top
DIYNewbie
Junior Member
PostPosted: Sat Sep 08, 2007 9:29 am    Post subject: Add User to Ignore List Reply with quote
Sorry about that!
Back to top
PostPosted: Sat Sep 08, 2007 10:01 am    Post subject: Add User to Ignore List Reply with quote
What type of heating system do you have?
Hinton heating is away for the weekend and he is the expert Crying
If it is a combi I would be guessing that it could be the diaphgram/ diverter valve, but that is only a guess.
DIY | DIY Video
Back to top
DIYNewbie
Junior Member
PostPosted: Sat Sep 08, 2007 12:11 pm    Post subject: Add User to Ignore List Reply with quote
The heating system is:
-> Boiler and Programmer in kitchen (ground floor)
-> Cylinder in airing cupboard (first floor)
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers All times are GMT
Page 1 of 1
