Ultimate Handyman Home
CENTRAL HEATING
Goto page Previous  1, 2
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers
sji1
Junior Member
PostPosted: Mon Jul 30, 2007 1:35 pm    Post subject: no hot water Add User to Ignore List Reply with quote
I have just encountered this problem having to drain down the system to fit a faulty valve on a rad, I have central heating but no water although a few upstairs rads get hot when just hot water used.
Do I need to undo the heat exchanger pipes to the cylinder to get rid of an air lock? after draining down the system again?
The heat exchanger is fed from a glow-warm back boiler.
Back to top
tim'll fix it
PostPosted: Mon Jul 30, 2007 1:56 pm    Post subject: Add User to Ignore List Reply with quote
its worth a try :grin:
Decking
Back to top
Hinton Heating
Gas/Heating Expert
PostPosted: Mon Jul 30, 2007 5:19 pm    Post subject: Add User to Ignore List Reply with quote
just be very careful, as you could crack the water connection, on the cylinder.
www.hintonheating.com
Back to top
sji1
Junior Member
PostPosted: Wed Aug 15, 2007 12:19 pm    Post subject: primatic cylinder hw not getting hot just ch Add User to Ignore List Reply with quote
ok I am more savey now, I have back boiler with a primatic cylinder.Ch is fine but on hw alone a few rads get hot not the HW cylinder. have i lost the air bubble? you might say change the whole system but before going there can I rescue what I have. should I backfill the whole system to clear any air locks or trapped sludge in the primatic cylinder or gravity feed pipes to it. Surely just draining down and refilling a working system cannot make it beyond repair.Any one who has knowledge of these sytems help! please will try anything before scrapping the lot.
Back to top
sji1
Junior Member
PostPosted: Wed Aug 29, 2007 11:20 am    Post subject: backboiler with primatic cylinder Add User to Ignore List Reply with quote
I,ve solved it by backfilling from the drain cock any air lock in the gravity fed pipe from the boiler was removed and now my old system works just as before. Many plumbers tried to get me to install a modern day system but It would take a while to get back £2,500 to change to a new system. I reckon 10 years. again thanks
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers All times are GMT
Page 2 of 2
