It is currently Wed Oct 17, 2018 1:10 pm
 Post subject: Central heating problem
PostPosted: Thu Apr 27, 2017 11:40 am
Has thanked: 5 times
Hoping someone might be able to answer this fairly easily. We recently had some plastering and decorating done which meant taking two radiators off the wall. They're now back on and we've also had an additional radiator fitted. The problem we have is that we now need to turn the thermostat up to 28 degrees to trigger a call for heat to the boiler. Could anyone tell me if this is likely to be because the system needs balancing or is it more likely to be a problem with the thermostat and it's just coincidence that it's happened now? We've bled the radiators and there are no hot or cold spots and everything is working fine apart from this.
I've kept this short rather than go through the whole saga of our dealings with the plumber who did the work but I'm happy to give more info if needed (as long as it doesn't get too technical for me!)
Thanks in advance for any help given.
PostPosted: Thu Apr 27, 2017 12:55 pm
Has thanked: 422 times
Been thanked: 3903 times
Any thermostat works on room temperature fall/rise so if the room is say 26 ish then the stat will stay off.
Hang a thermometer on the wall and take readings, (needs to be near the room stat) other than that unlikely to be any problem.
My lounge is currently reading 32.9c :shock: I would need to turn the room stat up to at least 34c for the boiler to turn on.
For this message the author thescruff has received gratitude : frances
PostPosted: Thu Apr 27, 2017 1:10 pm
Thanks thescruff - just tried this (with the thermometer balanced on top of the thermostat). Temp in the hall is 16 degrees but I needed to turn the thermostat up to 26 before it clicked.
PostPosted: Thu Apr 27, 2017 1:16 pm
They can fill up with fluff over time so clean the airways, otherwise replace if it's out of sync.
PostPosted: Thu Apr 27, 2017 1:22 pm
So the fact that we've just had walls replastered and the entire house is hidden in a dust cloud could be behind all this? Thanks very much thescruff - I don't know the first thing about central heating but one thing I do know about is cleaning!! I'll see what effect that has.
PostPosted: Thu Apr 27, 2017 1:43 pm
Has thanked: 1485 times
Been thanked: 3791 times
Be careful if you take the cover off the thermostat; there is a possibility that you'll be exposing 230V live wiring.
For this message the author wine~o has received gratitude : frances
PostPosted: Thu Apr 27, 2017 1:47 pm
I wondered about electrics - that's why I haven't touched it yet. Think I'll wait till OH gets home if electricity is involved. Apart from the general dangers, I'm one of those people who seems to be permanently full of static electricity so probably best if I stay well away.
Edit: Would the thermostat be on the same fuse as the boiler? We have a three storey house - thermostat on ground floor, boiler on top floor. Or would the thermostat be on the circuit for ground floor power?
PostPosted: Thu Apr 27, 2017 1:48 pm
Switch off the lecky at the boiler if in any doubt.
PostPosted: Thu Apr 27, 2017 1:50 pm
Beat me to it :-) Thanks wine~o
PostPosted: Thu Apr 27, 2017 2:18 pm
Probably not the same fuse but could be. I would wait for the other half.
PostPosted: Sun May 07, 2017 7:52 am
Has thanked: 64 times
Been thanked: 543 times
With modern thermostats we tend to forget about the older models, some had a glass file with mercury in and as it got warmer it would tilt the file and the mercury would role from one end of file to the other, it actually worked well, however the thermostat needs to be level, even a little off level and the thermostat will be out.
As we moved away from them we still had the bi-metal strip which physically opened and closed the contacts, the hysteresis was massive so to reduce it they had a small heater fitted, for this to work it needed a neutral, many would fitted without the neutral and the result was it had a massive difference between on temperature and off temperature.
With hard wired thermostats there are no problems, but with wireless you can actually lose the wireless connection, I had a Horstmann HRFS1 fitted in my mothers house, spec seemed great, but it would simply fail to both switch on and off, had it both ways, house well over and well under temperature.
