Page 1 of 1
[ 4 posts ] |
| Author |
Message |
clintmurphy
Posted: Tue Nov 29, 2011 8:52 pm |
| Newly registered Member |
Joined: Thu Oct 27, 2011 9:41 am Posts: 14 Has thanked: 1 times Been thanked: 0 times
Replaced radiator downstairs in the hall and was feeling very pleased with meself. Needed to drain down the system because the old valves wouldn't budge. When I tried to refill, I came across a blockage, bled and bled and bled to no avail. Eventually, I put a hose up thru the drain cock in one of the lower floors. Managed to fill all the rads downstairs but there's nothing upstairs. The water started flowing back on me when I had it turned up high. There's a fair amount of microbore upstairs and i suspect some sludge too. The expansion tank in the attic is full. It's an open system.
Any ideas how I'd move this? Time was it I'd take out the radiators and wash them through out the back garden but I just can't lift them anymore.
Thanks for your help. Clint
| Top |
thescruff
Posted: Tue Nov 29, 2011 8:57 pm |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39971 Has thanked: 187 times Been thanked: 2110 times
Should have cleaned the header tank before you drained down.
Is there a 3port valve and did you put in the manual position.
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
Razor
Posted: Tue Nov 29, 2011 8:59 pm |
| Senior Member |
Joined: Wed Nov 14, 2007 10:21 pm Posts: 5138 Location: Northampton Has thanked: 76 times Been thanked: 372 times
If you drain some water off does the header tank empty?
_________________ As always help on here is free, however if you think you have saved a decent sum of money why not click the link to find out about the charity we're currently supporting? A couple of quid makes a real difference. donnas-dream-house-charity-t52110.html
| Top |
register or
log in
clintmurphy
Posted: Tue Nov 29, 2011 9:21 pm |
I tied up the ball cock before I drained the system. I'm not sure what the configuration is in the attic. It's very hard for me to get into it because I'm injured. I turned on/off the water at the mains valve under the sink. I took a feed off the washing machine valve to pass the water back up.
I just drained a basin full of water off and the tank did refill..........slowly.
| Top |
register or
log in
Page 1 of 1
[ 4 posts ] |
