Page 1 of 1
[ 3 posts ] |
| Author |
Message |
Bontjack
Posted: Tue Sep 20, 2011 9:48 pm |
| Newly registered Member |
Joined: Tue Feb 08, 2011 8:16 pm Posts: 10 Has thanked: 2 times Been thanked: 0 times
I shall be re-rendering a stone wall that has been previosly cement rendered and is showing many hairline cracks as well as an area which has completely failed and the render has blown and bulging from the wall. I have read from previous posts that lime to be added to the cement render top coat to aid flexibility and reduce the chances of cracking. should lime not be used in the in the scratch coat too and should you still use plasticiser and waterproof additives to the mix? what mix ratios for scratch and top coat are required?
| Top |
moderator2
Posted: Wed Sep 21, 2011 7:45 am |
| UHM Super Moderator |
Joined: Fri Jan 27, 2006 10:54 pm Posts: 1085 Has thanked: 30 times Been thanked: 55 times
I will move this to plastering forum, you may get more response there.
| Top |
register or
log in
cotswold builders
Posted: Sat Sep 24, 2011 5:45 pm |
| Senior Member |
Joined: Sun Sep 11, 2011 3:35 pm Posts: 820 Has thanked: 15 times Been thanked: 160 times
Sounds like the render didnt bond to the wall, hack it all of and give the wall a SBR slurry, paint it on the wall and apply your scratch while the slurry is still tacky, with water proofer and febmix, at a ratio of 4 sand to 1 cement. Next day float coat at 5 sand to 1 cement, add febmix, no waterproofer.
| Top |
register or
log in
Page 1 of 1
[ 3 posts ] |
