Ultimate Handyman Home
Cellar brickwork deteriating and signs of salt
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum
deden56
Junior Member
PostPosted: Sat Aug 16, 2008 12:14 am    Post subject: Cellar brickwork deteriating and signs of salt Add User to Ignore List Reply with quote
I have a cellar and the bottom 5 or 6 rows of bicks in places are showing signs of salt coming from them and the outer face of some of the bricks are starting to come away.the brick work has been painted approximatly 10 to 15 years ago.Is there anything I can apply to the brick work to stop the salt and the bricks deteriating .
Back to top
Griffin
Junior Member
PostPosted: Thu Sep 04, 2008 10:55 pm    Post subject: Add User to Ignore List Reply with quote
There are brush applied products available which you can use to seal the brickwork with, have a look in your local build center and ask a member of staff if unsure. You might need to wire brush off any old loose material on the wall surface before applying a new seal though.
Griffin
Back to top
RemedialExpert
Junior Member
PostPosted: Wed Sep 24, 2008 1:13 pm    Post subject: Add User to Ignore List Reply with quote
the product griffin is on about keeps water out, this is not what you requir as it is internal, you need something to allow it to dry through without spalling the faces of the bricks. Lime render them with traditional products, this will allow the bricks to dry naturally through the product without damage to the faces.
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum All times are GMT
Page 1 of 1
