It is currently Thu Apr 26, 2018 8:00 pm
PostPosted: Sat Sep 30, 2017 8:33 pm
Evening,
In a double bedroom there is a ceiling light which is a rose which has 2 neutrals and 2 lives coming out.
In a single bedroom there is a also a rose with 3 neutrals and 3 lives coming out
I have tried to wire up both and, for the double bedroom, no combination I have tried works. For the single bedroom I can wire up the light so that it turns on but the switch does not work.
I've tried finding the switched live using a non contact voltage tester (http://www.ebay.co.uk/itm/Non-Contact-AC-12V-1000V-Voltage-Tester-Detector-Pen-Volt-Alert-Sensor-LED-Light/162468460669?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649) and, whilst the circuits are on, does identify the switched live for the single bedroom, says that both the neutrals have a current for the double bedroom.
I'm at my wits end, please help
PostPosted: Sat Sep 30, 2017 8:43 pm
Has thanked: 40 times
Been thanked: 1228 times
You could try posting pictures, may be able to help, but I think a meter would be better.
Non contact voltage indicators in my opinion are a waste of time since they will light up at almost anything. (Rub one up and down on your shirt / jumper)
They also can not tell you if a neutral is present.
I would suggest you buy a multi meter, as they are better, and more useful, you can get one for less than £10 from Screwfix
PostPosted: Sat Sep 30, 2017 10:36 pm
Single bedroom photo (3 live 3 neutral),https://my.pcloud.com/publink/show?code=XZXJ8k7ZSvMlfipS8Wzz5sI9ktSzMjsrNnWy
Double bedroom photo (2 live 2 neutral), https://my.pcloud.com/publink/show?code=XZVJ8k7ZwPvLXKvzHuL5acgVPVRvF8qybVCk
I did buy a 17th edition series test meter, https://www.test-meter.co.uk/17th-edition-safe-isolation-kit-test-meter/, but it didn't register any voltage when I tested on the double bedroom light
pics attached. Mod 2.
PostPosted: Sun Oct 01, 2017 12:16 am
What you have linked to is an isolation kit that also has a voltage indicator.
(For what its worth most of what you have is of no use to you, and you could have got the voltage indicator for considerably less, and as I said a multi meter is even less and would have been more use to you.)
The voltage indicator you have only works with the mains on.
Re-reading your post, it shows you have no concept of how a UK lighting circuit is wired, and what you are "looking" for, so as I would like to see you post again, I am sorry but I feel that you should call an electrician to do this job for you.
(Or wait and see what they say on the other forum you asked this question)
PostPosted: Sun Oct 01, 2017 7:56 am
Approved Electrician
Has thanked: 159 times
Been thanked: 552 times
Single bedroom. All the reds into the loop, separate the blacks and test for voltage. The switched live will be confirmed by switching the lightswitch. One of the neutrals may show as a live, that's normal.
PostPosted: Wed Oct 04, 2017 11:12 pm
I got the single bedroom light working using my new LAP multi meter with the resistance setting on 200 ohms, measuring for resistance between each live/neutral and ground to find which is the switched live and neutral.
I did use this method to find the switch's live and neutral for the double bedroom. I have tried the switched live (black cable with red tape) in the live, all other neutrals > neutral, the other reds to the looped but the light just won't turn on. The double bedroom has 2 lives and 2 neutrals, one a switch live/neutral pair and the other a consumer unit live/neutral pair. Please can someone assist in letting e know which wire goes where using the pics I attached? Thanks
File comment: light
PostPosted: Thu Oct 05, 2017 5:56 pm
Has thanked: 1406 times
Been thanked: 3634 times
If all else is wired correctly then one black to Live the other to neutral and the reds in loop.
If it doesn't work there is either a fault with the wiring at the previous light or a break in the cable between the 2 lights or a loose connection at the switch or the switch itself is faulty.
PostPosted: Thu Oct 05, 2017 10:45 pm
All other lights in the house turn on/off with no problems. I rechecked the live neutral cable under the light switch to confirm that they were the switched live and neutral. The switched live (neutral) had a positive resistance when connected to ground and the live, when connected to ground, had a positive resistance. However there was zero resistance between switched live (neutral) and the live. I also checked the switch's live (in the COM) and the switched neutral (in L1) and there was the same resistance valves for the switched live (neutral) and the live. However, again, zero resistance between switched live and neutral (when isolated with switch on).
When unisolated and the switch is off the 5W LED glows slightly, when the switch is on the LED turns off. I used a non contact voltage tester when unisolated and it buzzed on all lives and neutrals. The connection at the switch is working, the wires are definitly connected. Any suggestions? I suspect the switch mechanism is broken
PostPosted: Sat Oct 07, 2017 6:03 pm
bypass the switch by putting the permanent and switched live in the same terminal. If the light works then the switch is fooked.
Edit. Lecky off first.
