Ultimate Handyman Home
Ceiling Question
Goto page 1, 2  Next
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Carpentry/Joinery Forum
freeman
Junior Member
PostPosted: Tue Apr 17, 2007 7:59 pm    Post subject: Ceiling Question Add User to Ignore List Reply with quote
What's the best way to find a ceiling joist? I've got an electronic stud detector, is that the best thing to use?
Back to top
PostPosted: Tue Apr 17, 2007 9:06 pm    Post subject: Add User to Ignore List Reply with quote
You can often find them this way as the nails or screws that hold up the sheets are metal. They are often 18m inches apart, but could be more.
If you find the first one and then measure between that one and the next one then you will have the measurement for the joist spacing Wink
Or you can lift the carpet in the room above and measure the distance between the screws or nails holding down the floorboards.
DIY | DIY Video
Back to top
Gadget
Jack Of All Trades
PostPosted: Tue Apr 17, 2007 9:10 pm    Post subject: Add User to Ignore List Reply with quote
Sorry to correct you Chez, but the joists will be 16" apart, or near!!....18 meters is one hell of space!!.... Laughing
By eck!
Back to top
View user's profile Send private message Send e-mail MSN Messenger
petengade
Member
PostPosted: Thu Apr 19, 2007 12:57 am    Post subject: Add User to Ignore List Reply with quote
I normaly tap the plaster board ceiling with a hammer and where solid (does not sound hollow) is the joist, then bang a 2inch nail in a little to find the width then find the centre and go 16in centres, on lath and plaster hit a little harder to find the joist.
Back to top
panlid
PostPosted: Thu Apr 19, 2007 6:26 am    Post subject: Add User to Ignore List Reply with quote
have a look in the ceiling Thumbright
Back to top
petengade
Member
PostPosted: Thu Apr 19, 2007 7:00 am    Post subject: Add User to Ignore List Reply with quote
In a top floor flat with a flat roof? I didn't think of that Bang Head
Back to top
panlid
PostPosted: Thu Apr 19, 2007 7:20 am    Post subject: Add User to Ignore List Reply with quote
ok i'll be serious. normally you will find a joist at the edge of a ceiling. use a small drill to find which edge. then as stated before have a look at 16 inch centres. you wont be far out. depends if you are replastering or not. also as stated before you can normally tap with a hammer and find the solid sound of a joist. stud finders are ok if a good one. if not it is as much use as a dildo in a morgue.
Back to top
petengade
Member
PostPosted: Thu Apr 19, 2007 7:37 am    Post subject: Add User to Ignore List Reply with quote
Nice turn of phrase Rolling Eyes Laughing Have found in the past joist's are not always at the edge of a ceiling when stud walls have been erected, 2inch nail quicker than a drill, can always put the nail back in my pocket. Wink
Back to top
PostPosted: Thu Apr 19, 2007 7:58 am    Post subject: Add User to Ignore List Reply with quote
just keep in mind any" odd inches " will be lost at one side or the other so the next joist mat be an odd amount away from the first so if you can locate the second it should be even spacing from that point
also some measuring tapes have diamonds /dots or squares marked on them for marking out
Back to top
panlid
PostPosted: Thu Apr 19, 2007 8:01 pm    Post subject: Add User to Ignore List Reply with quote
so is this a room that is in the middle of the house and not joining an outside wall?
no..... at the moment i am thinking of every room in my house and everyone except the cupboard under the stairs is connected to an outside wall..
as for the nail versus drill decision. use whatever you want. i only use a drill because have you ever tried knocking a nail through a lathe and plaster ceiling to find a joist? it may not but sometimes does create cracking if you hit the lathe.
but hey ho ill let you find that out yourself one day Rolling Eyes
oh sorry, do i insert a wink here? Wink
Back to top
bathstyle
BATHROOM DESIGN AND INSTALLATION
PostPosted: Thu Apr 19, 2007 8:12 pm    Post subject: Add User to Ignore List Reply with quote
How on earth is nailing a ceiling quicker than drilling it to find a joist?
I either use a drill from below or hop into the loft and drill a hole either side of each joist, then snap a chalkline on from below.
Back to top
petengade
Member
PostPosted: Fri Apr 20, 2007 7:42 pm    Post subject: Add User to Ignore List Reply with quote
Had to fire board a lot of ceilings and corridors, and hang one hour fire doors, not just one bathroom, so found nail quicker than keep picking up and putting down a drill, have retired now Panlid. sorry if wink annoyed you. (but still not too old to learn)
Back to top
panlid
PostPosted: Fri Apr 20, 2007 8:21 pm    Post subject: Add User to Ignore List Reply with quote
no worries peter. more than one way to skin a cat.
by the way, you wink all you want . by the way, is a past wink a w*nk? Confused Wink
Back to top
jason123
PostPosted: Mon Apr 23, 2007 7:55 pm    Post subject: Add User to Ignore List Reply with quote
I found mine in a local timber merchants, you can find them in yellow pages. Thumbright
Stella Stella Stella oy oy oy
Back to top
petengade
Member
PostPosted: Mon Apr 23, 2007 8:24 pm    Post subject: Add User to Ignore List Reply with quote
A cat or a w*nk or 2inch nails you found in Yellow pages Jason?
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Carpentry/Joinery Forum All times are GMT
Goto page 1, 2  Next
Page 1 of 2
