www.ultimatehandyman.co.uk Forum Index -> Electric Forum UK
-> Lighting |
| Author |
Message |
hamish62 Junior Member
Posted: Sat Jul 19, 2008 10:16 am Post subject: Ceiling light wiring... |
just a quick question.
I am replacing a ceiling light and i have 3 sets of wires: 2 sets are red,black,earth but the third is red,red,earth.
I'm happy to connect the first 2 but i'm at a loss with the third.
Your help/advice would be appreciated. |
| Back to top |
ultimatehandyman Site Admin
Joined: 16 Jul 2005 Posts: 9255 Location: Darwen, Lancashire
Posted: Sat Jul 19, 2008 10:33 am Post subject: |
Hi Hamish,
This should be simple.
It sounds like they have used twin red and earth for the switched live wires, instead of sleeving the black wire on twin core and earth-
Some sparks do use this instead of twin core and earth as it saves sleeving the black wire.
I have attached a picture of what you probably have- _________________ DIY | DIY Video |
| Back to top |
Posted: Sat Jul 19, 2008 10:54 am Post subject: |
Thanks for the reply.
The fitting on the new light has Live/ earth/ neutral so, to be clear, i can treat one of the red on the third cable i mentioned as a black? |
| Back to top |
Posted: Sat Jul 19, 2008 11:02 am Post subject: |
The two red wires from the same cable will be the permanent live going to the switch and the switched live coming back from the switch.
Take a look here-
http://www.ultimatehandyman.co.uk/diy/electrics/light_fitting/changing_light_fitting.htm
But instead of having a cable going to the switch with the permanent live in red and switched live in black (sheathed red) you have a permanent live in red and a switched live in red also. _________________ DIY | DIY Video |
| Back to top |
Posted: Sat Jul 19, 2008 2:20 pm Post subject: |
| Thanks for the help. |
| Back to top |
Posted: Sat Jul 19, 2008 2:25 pm Post subject: |
| Thanks again... need post count of 5 to read pm!! |
| Back to top |
