It is currently Wed May 23, 2012 3:13 am
 Post subject: Ceiling Joist Span
PostPosted: Wed Dec 28, 2011 11:07 am
Hi all,
the question I have is, what spacing should I use for the 2"x2" timber which is hung under block and beam flooring using universal clips. The plasterboard will be 12.5mm sheets, should I space at 450mm or 600mm?
Thanks for any help.
 Post subject: Re: Ceiling Joist Span
PostPosted: Wed Dec 28, 2011 11:29 am
Has thanked: 14 times
Been thanked: 3 times
400 centres I would say. Watch out for the plasterboard being 1220mm wide, which would put your centres at 407mm. Centres wider than that and the plasterboard is likely to sag.
PostPosted: Wed Dec 28, 2011 12:43 pm
Has thanked: 7 times
Been thanked: 128 times
I would go for 400mm centres, although many trussed roofs are at set out @ 600mm centres and this is then boarded; more noggins will be required if you go for 600 centres.
To the best of my knowledge P/b is 1200mm wide now, not seen imperial widths (full 4'0") for a long time.
PostPosted: Wed Dec 28, 2011 1:03 pm
Been thanked: 66 times
as said in an earlier thread... all the stuff i do i have to set stuff out at 16 inch centres. though i mainly use the handy boards.
in the other thread i stated if i set out at 400 centres i have to cut small strips off every board.
dunno if its a manufacturer thing or something? i use lafarge boards. but think ill be changing as the quality of them is getting worse lol...
Users browsing this forum: Google [Bot] and 1 guest
