It is currently Wed May 23, 2012 3:13 am
 Post subject: Cedral cladding
PostPosted: Fri Jan 20, 2012 8:29 pm
Has thanked: 7 times
Been thanked: 128 times
Just finished this lot, I sincerely hope that I never have to use the stuff again.
House
Garage
and even the shed
 Post subject: Re: Cedral cladding
PostPosted: Fri Jan 20, 2012 8:48 pm
Has thanked: 14 times
Been thanked: 135 times
wow looks like you had fun :wink: i fitted some afew years ago not as much as you tho (thank god) and it still looks as good now as the day i fitted it
what did you use to cut it?
PostPosted: Fri Jan 20, 2012 9:27 pm
Has thanked: 6 times
Been thanked: 108 times
Continuous diamond blades work well on cement fibre roofing sheet, but normal tct wood blades cut it fine....probably need a new blade for doing decent stuff after though....thats what Cedral is isn't it?
Looks a nice install job.
Almost makes it look American :shock:
PostPosted: Fri Jan 20, 2012 9:39 pm
I've had all the fun I need for now! :roll:
Diamond blade in the boss's chop saw to start with but it just kept clogging up with the dust on the slide rails, (needs a complete strip down and clean now) in the end I just used a diamond blade in a small angle grinder - windy days were best.
It took the edge off a TCT blade very quickly.
