Ultimate Handyman Home
Caulking cracks?
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum
milly18
Junior Member
PostPosted: Wed Jun 27, 2007 11:45 am    Post subject: Caulking cracks? Add User to Ignore List Reply with quote
I had a contractor telling me that if you use paintable caulk to fill cracks in plaster and then mud over it, it will last longer? Says when the house settles the caulk is flexible and the cracks won't reappear. Has anyone ever heard of that?
Back to top
leebwk
PostPosted: Thu Jun 28, 2007 7:09 am    Post subject: Add User to Ignore List Reply with quote
Hi Milly18,
Caulk is usually an acrylic based paintable mastic which is applied via a mastic gun, this is great for internal angles and wall to ceiling joints plus around skirting and so forth, but not really any good to use on a flat ceiling or wall.
How old is the ceiling and is it skim over plasterboard,if so i would have it reskimmed because by the time you've filled all the cracks and prepared ready for painting you could have had it reskimmed.
Hope this helps.
What was the best thing before sliced bread?
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum All times are GMT
Page 1 of 1
